On the Bosch compound sliding miter saw, turn the blade nut clockwise to remove it.
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_f6ca18ca1db028ed
SOURCE: How to replace lockdown pin DW708 12" sliding compound mitre saw
you are going to have to drill the inside pin out. be sure to center punch and drill a pilot hole. hope this helps
SOURCE: putting on a saw blade
Well M8:) try to to unloose it backwards, It dosent loose as usal, you need to posh the otherway. Nornaly you loose things from right to left, this one (and other items that cut) you loos from left to right.
Good luck to you
SOURCE: Compound mitre saw won't shut off unlss unplugged
Relace the switch.
I am presuming the lock button has not been inadvertently pressed ... Check that first.
The condition you deacrive is dangerous. Please fix it before you use it any more.
If you require additional assistance, let me know.
Otherwise, check RepairClonic.com for parts and technnical instruction from their crack crew.
Thanks for the opportunity to lend you a hand
a
SOURCE: how do you replace the blade on as Protech 8 1/4
there should be a spindle lock on the opposite side of the blade bolt,, make sure that when you replace the blade that you install the flanges correctly and if there a spacer that it is in place.
