My phone is not ringing when I get incoming calls, beeping when I get txts, and it won't go on loud speaker. The volume is high.
Its set to normal profile, with ringing volume high.
Please advise.
Some how your phone was reset or had the tone turned off. Just follow the below guide and your audio should come back on. I would do a soft reset (turn off the handset, remove the battery then reinsert) before performing the instructions.
Tone settings
To select a ringing tone for voice calls, select Tones >
Ringing tone.
To select a ringing tone for video calls, select Tones > Video
call tone.
To set the ringing type, select Tones > Ringing type. You
can also set the device to sound a ringing tone that is a
combination of the spoken name of the caller and the
selected ringing tone, when someone from your contacts list
calls you. Select Tones > Say caller's name.
To set the volume level of the ringing tone, select Tones >
Ringing volume.
To set the various alert tones, select Tones > Message alert
tone, E-mail alert tone, Calendar alarm tone, or Clock
alarm tone.
To set the device to vibrate when you receive a call, select
Tones > Vibrating alert.
To set the volume level of the device keypad tones, select
Tones > Keypad tones.
I have included a link to download your user manual if needed, it comes as a PDF file so you need to have adobe PDF down loader
http://nds1.nokia.com/phones/files/guides/Nokia_E63-1_UG_en.pdf
Dunnbiker,
I'm feeding my satellite receiver into aux.
regards
michel
That's part pf an answer. WHAT exactly are you feeding into it (audio, video, cable type, digital, analog??
Has it ever worked with this unit or another?
I'm feeding the device with analog audio signal from my satellite tuner. I use RCA phono plugs (white and red ones)
I tried the same by feeding the aux with audio signal from my Wii.
Same problem.
Cables aren't broken. I verified that by using them with another device.
regards
Michel
onboard sound (dvd/cd) is fine. No problem at all. Never tried the radio.
greetings.
michel
