First time ever dvd player is asking for a password
Have had this dvd player for 2 years, and now is asking for a password, we have never setup a password, and the screen is frozen? Any info to fix this please, thanks.
Re: first time ever dvd player is asking for a password
Password = 136900 (that's the default password). Not sure how to stop it from asking though, cause that's my problem. Evertime I play a divx disc it asked for a password.
Fortunately Sony built in a default password for occasions such as yours. The procedure is laid out on page 45 of your manual. Follow these steps to make use of the built in password:
1) Go to the Parental settings on your menu and choose PASSWORD.
2) input "136900" in the box marked "Old Password".
3) Enter a new password in the "New Password" box. Enter the same password in the "Verify Password" box then press Enter to confirm.
You should now be able to use the new password that you setup above.
Please follow the instuctions below to reset the password and switch off the parental control on the Zenith DBV412.
1. Switch on the TV and DVD player 2. Switch the TV to the input for the DVD player 3. Remove any disc from the player 4. Press the SETUP key on the Zenith remote to open the on-screen menu 5. Press 2 1 0 4 9 9 using the numerical keys on the Zenith remote. 6. Press SETUP again to close the menu
This will clear any password that has been set. Now you need to switch off the parental control:
8. Press the SETUP key to open the on-screen menu again 9. Use the down arrow to highlight the PADLOCK for the parental control settings 10. Press the RIGHT arrow once to enter the parental control menu 11. Highlight RATING and press the RIGHT arrow once.
You will be asked to set a password. Enter something simple and easy to remember, e.g. 0000 then press ENTER. You will need to confirm the password by entering the same number again, then press enter again.
12. Use the UP/DOWN arrows to highlight UNLOCK then press ENTER 13. Press SETUP again to close the menu
You should now be able to insert your Across the Universe disc and play it. If you are still unable to watch the disc or you are unable to switch off the parental control feature, please let me know.
If there is a key symbol illuminated on the display, press and hold the "LOCK" button on the Zenith remote. This is located near the bottom of the remote, near the REC/ITR button.
For the parental lock feature, press the SETUP button on the remote then use the UP/DOWN arrow keys to highlight RATING and press the RIGHT arrow once. This will open the rating menu. Press the DOWN arrow repeatedly until UNLOCK is highlighted then press ENTER. Finally, press SETUP again to close the menu.
You may be asked to enter a password to change the rating setting. If you know the password (4 numbers), enter it when prompted. If you don't know or you've forgotten the password, close the menu using the SETUP key, then press SETUP again to re-open the menu.
Dont select anything here, simply press 2 1 0 4 9 9 using the number keys on the remote and then press ENTER. This will clear any password that has been set. You will then be asked to set a new password the next time you try to access the RATING section of the menu.
Please try the above. If you get stuck at any point, post another message here and I'll get back to you immediately.
Parental Control Blocks playback of rated DVDs based on their content. Not all discs are rated.
1. In DVD Stop mode, press SETUP. 2. Select Others > Parental. 3. Select the desired Parental Control rating from "1 Kids" to "8 Adult", then press ENTER. 4. Enter your password using the 0-9 keys, then press ENTER. • The factory default password is 3308. If you forget your password, this will always work.
Password Changes the Parental Control password. 1. In DVD Stop mode, press SETUP. 2. Select Others > Password. 3. Enter your old password using the 0-9 keys. 4. Enter your new password. 5. Re-enter your new password and press ENTER.
Try using the password 136900. If this passcode works for you, then access the setup menu from your remote, and under the general setup menu, choose the Disc Unlock option.
Try using the password 136900. If this works for you, then using your remote, access the general setup menu and choose the Disc Unlock option.
Hope this helps!!
With no disc in the player 1) turn on. 2) press open key. 3) press 5168. 4) select rating. 5) select "adult" or whatever rating you would like. 6) select setup.
1) Open the DVD Door, on remote press Setup, Right, Right, Right (that’s the arrows in the middle of remote)
2) Enter 9653,a service page will appear,
3) Use Up/Down Bottom to change region Codes
4) Set to 0 (zero) for multi-region
