Nokia N70 Cellular Phone Logo
A
Anonymous Posted on Jul 01, 2010
How do you remove the _palbtn ? its duplicating my pic and video on my celphone?
Anonymous
Level 2:
  • Expert 148 Answers
  • Posted on Jul 27, 2010
Anonymous
Expert
Level 2:
Answers
148
Questions
6
Helped
31423
Points
403
_palbtn is a cache or preview feature of nokia.It is used to show taken pictures speedly by creating it's duplicate(only size will be some kb's) You can manually delete _palbtn by going to filemanager and goto images goto _palbtn delete it.This feature cannot be turned off.Thanks
My camera pics upload to my computer in duplicate,one set correctly & one set in video 320-240 resolution,Why?
What make and model camera/phone? Could it be that you have it set to record both video and still?
Apr 04, 2013 • Cell Phones
How can i remove the dictionary on my celphone several letters and words are appearing on my screen during im texting.. how can I remove it??
Hello Sir :)
This is not a problem i'am using the same cell phone i tell you what to do. when you type a message from keypad you see a button there T9 just tap it and you'l get the dictionary off :) i'm gona attach a pic now that will make you to understand more easily.
Keep using FiXya. Thanks :)hadimughal.jpg
When transferring pics to computer from camera it will transfer some and then not transfer others saying they are duplicates when they are not. How do i get these others pics onto the computer?Ads by...
Your camera is not numbering consecutively...it is starting over each time...hence the duplicate numbers. You can use a card reader to download the pics to a folder you create on your desktop. From there, you can right-click the duplicates and rename them.
Failure in power supply
Try to power drain your celphone anshul_sood, turn off celphone, remove battery and hold the power button of your celphone for 5 seconds. Then plug back the battery and charger. Turn on the celphone..
If symptom persist, go to the nearest nokia center in your place....
Hope this helps...
Picture download
Your camera is not numbering the pics consecutively. It is duplicating the numbers and your computer thinks the pics are already there. You are going to have to figure out the duplicates and download them to a separate folder and then rename them.
2helpful
No power even i am charging the celphone.not charging
It means that the battery life is over. Goto the phone dealer and get the original battery from the samsung. Do not go to any another dealer, you may get duplicated one
2answers
I can't delete songs off my YP-T9J
It's not a hard work that you can have a try powerful program Leawo Tunes Cleaner. Leawo Tunes Cleaner is a professional duplicate music remover.
Step 1. Run Tunes Cleaner and Scan Duplicate Songs
After kicking off Leawo Tunes Cleaner for Windows, click the "Clean-up Duplicates" entry. The program provides 2 duplicates scanning modes: Quick Scan mode and Deep Scan mode. Select one of them to scan duplicate songs.
Step 2. Add Music Files for Duplicates Removing
You could delete duplicate songs in iTunes music library by directly clicking "Scan iTunes" button or click "Add" button to load music files for duplicates removing. Or you could directly drag music files from your local folder to the software for duplicates removing.
Step 3. Start Deleting Duplicates
After loading source music files, click the "Scan" button on the upper-right corner to start scanning duplicates. The program would display all duplicates clearly and suggest what to remove. You could decide which duplicates to delete by checking them and then click the "Remove" button to remove duplicate songs.
tunes-cleaner-scan-result-gwujvob1wsqcwi5j4bnkubbk-3-0_0.jpg For more details, check: How to Delete Duplicate Songs
How to use my bluetooth on my cellphone n95
U need a printer fixed up with bluetooth device.
If u have the required one, with the help of bluetooth, u can print ur pics !!!!!
the process to use it same as with other bluetooth fixed phones.
Kindly send me feedback.
Sajan
3answers
Switch off button disabled)
this mobile has some soft ware issues same thing happend to my friend and we went to service station and we upgrade rthe soft ware
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
