1. try reducing the band for some time, from 3g to 2g.
else
2. reboot.
else
3. remove battery while keeping the phone on. reseat the battery, switch on .
it must work
have a good day.
sir,
the internal software of your N95 is corroupted. Don't worry! just sep to nearby "nokia care" service centre and tell them to fix it.
thank you for contacting fixya. have a nice day.
Start off with the simple things, does it work with another lens, is the AF/M switch in the correct postion for autofocus (AF), are the batteries good.
If all of the above are in order it maybe either the DC/DC converter on the bottom of the camera, this supplies power to various parts of the circuit. or it could be the motor drive transistors, these are located under the front cover and are located where you finger tips rest on the right hand side as you hold the camera.
Both these items are not really user changeable and I know the DC/DC units have not been available new for many years now.
I suggest you have a look for a friendly camera repair shop to pin point the exact cause.
You will have to keep in mind the age of the camera 23 years old parts are a big issue
Hey,
This is a problem that occurs often in all of the Sony Cybershot cameras. To fix this problem, hit the "Sony" logo on the front of the camera with one of your knuckles. I know it sounds abusive, but it works everytime! and with every Sony camera:)
Best of luck,
Matt
check the viruses in ur handset, it might have ggot locked with one of ur applications and than when ever u start that application it just gets shuts off, otherwise try to check out the battery back up, if this is not the case than restore ur handset once, and try but take the backup of ur data before reseting it.
