Rheem 50 Gallon FVR NATGAS Water Heater 6YR 22V50F1 Logo
Posted on Jul 24, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Model 41V50 Rheem water heater (50 gal. natural gas) and needs to be replaced. However, I can't find this model at any of the local stores. Has this been discontinued? If so, what can I get for a replacement?
vince janis
Level 3:
  • Master 718 Answers
  • Posted on Jul 25, 2010
vince janis
Master
Level 3:
Answers
718
Questions
Helped
256448
Points
1742
You don't need to find the same exact model to replace your water heater, any 50 gallon water heater will do unless you have a brand specification that you like to stick with.
I have Rheem model 41V50 leaking from the top...The top is a lid with screw....can I buy and replace the top ?
No.
Replace tank.
Buy 40 gallon from local Lowes and install yourself.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Under thin metal shell is a welded steel tank, surrounded by insulation and then covered with painted metal shell. The shell is what you look at.
The inside steel tank is made to withstand high pressure expansion that comes with heating water.
The steel tank has rusted out.
Turn gas control valve to vacation, so pilot light stays on, and then only heat enough water as needed until you can replace tank.
Prevent next tank from rusting by replacing anode rod, and ground water pipes.
http://waterheatertimer.org/How-to-maintain-water-heater.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Where can i get a 21dv50 water heater to buy
21dv50 is discontinued. This is ordinary tank-type 50 gallon gas water heater.
Amazon sells 50 gallon 22V50F1 Rheem water heater for $420 with free shipping ... but who carries the warranty?
Frankly you can get in-store returns, and buy same quality gas water heater at local box store since Rheem makes GE water heaters at home Depot.
Other brands are equally good, as AO Smith makes Kenmore water heaters at Sears and Whirlpool at Lowes.
I prefer the AO Smith because maintenance is easier.
1helpful
Which one is compatable water heater to Rheemglas fury Model#41V50?
You have 6-year 50 gallon gas water heater:
42V50 would be the newer model number. They make tall and short models.
http://www.rheem.com/product.aspx?id=CC643E03-4C15-4775-B139-E504A95651F7
All brands of water heater are good.
So any 50 gallon gas water heater from local box store or hardware is good product.
Tanks with longer warranty last longer. So 9-year and 12-year water heater will last longer, unless you have very hard water or odor in water and need to change frequently.
I recommend avoiding water heaters with electronic controls since they are not protected from power surge and can cost more to repair.
Additional resources:
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
2answers
Rheemglas fury model # 41V50 the approx. 5 gal pressure tank above the water heater is corroded and leaking. how difficult to replace and what is the name of the tank
1) If tank is connected with single pipe to cold water line, then it could be expansion tank.
Add a comment with photo so I can see.
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
2) Take photo to plumbing supply store.
Expansion tanks unscrew from pipe. Simply install it and it has internal pressure bladder.
Has to install on cold water line.
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
3helpful
I have a Rheem 50 gal. natural gas water heater mod#21V50-6A followed all instruction and can't get pilot light to stay lit.
The most common reason a pilot light will not stay lit is a bad thermocouple. How old is the water heater? If the pilot light will light, but then go out when you release the safety button, that is a sure sign the thermocouple is bad. You can buy a replacement thermocouple at your local home improvement store. There is a small chance that the control valve has gone bad, but that is highly unlikely.
1helpful
Water heater leaking
Yes, you will need a new heater. The inner tank has rusted thru and it is way cheeper to replace the whole water heater than trying to fix the old one.
2answers
We have a 83 Gal. Rheem 41V50 40,000 Btu - What do we replace it with? It is leaking
The model number you gave is for a 50 gallon tank, not 83 gallon.
50 gallon ones are readily available, including the same model..
Top Rheem Water Heaters Experts
Mike Cairns
Mike Cairns
Sean Wright
Sean Wright
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
