You can only use the black ink cartridge without the color ink. But no need to replace them in your printer.
When you print just choose black and white for the printed text must be black not colored. But if you still received such notification...just try to replace the color ink cartridge to continue printing
Note:
As per my experience. printer with exclusive black ink alone will damage the printer easily due to unbalance printing of ink
Sorry, steve, that you are experiencing this problem.
According to canon.com's website regarding the i9900 InkJet Photo Printer:
Why color ink may be used when printing in black and white
Even when printing in black and white, color ink is used for the following reasons:
Automatic cleaning of the print head.
To prevent the print head nozzles from clogging, the print head is automatically cleaned periodically. At that time, a small amount of each color ink is consumed.
Therefore, although printing in black and white is performed, color ink is also consumed.
Color inks may be used to create black.
When printing in grayscale or on photo paper or when duplex printing, although printing appears in black and white, the color black may be created using the three (cyan, magenta, and yellow) color inks. Printers without a pigment black tank / cartridge will print black / grayscale will create a composite black using color ink even on plain paper.
Therefore, although printing in black and white is performed, color ink may be consumed.
In order to keep the heavy black ink from smearing on the page or in the printer, color ink is used when duplex printing to help create black text.
I might suggest taking out the color ink cartridges leaving only black there, but some printers don't take kindly to this. So, you may have to further experiment with magenta, cyan, and yellow to make it at least seem b&w to your best eye's judgment.
Now a days all HP ink catridges available at low price that means ink quantity is also low.So if you print heavy coloured pages it will deffinately consumes more ink.So print in gray scale or black and white consumes low ink. Compare to gray scale,black and white printing consumes very low ink. So print in black and white is the better choice.
The little cartridges are pigment for photo printing. The Large black cart is ink for plain paper (usually text) printing. If you select a photo paper in the print setup menu, you will use very little of the ink. To check the function of the large cart print out a test sheet from the printer maintenance menu. You may need to run a head cleaning to get all the nozzles to work.
Seems like the ink has dried in the print head or the control circuit to make the black ink print, is not working.
See my other post in the ip3000 section re. cleaning the print head and give that a go. I have got a print head doing that right now. If I can't ink to go thru the head thru either warm water washing - next step is to drop Video Head Cleaning fluid ( Iso Propyl achohol) onto the tiny screens on the print head to see if that will works its way through.
If you get ink coming thru the print head, and it still wont print black, then it may be an electronic problem. Other than cleaning the gold contacts on the back of the print head, there probably is not a lot more you can do other than look for a working secondhand pprinter - I love mine ( when its going)
I'm sorry, but there is no white ink in the cartridges in this printer, and there are no printers I know of by any manufacturer that have white ink to do what you're wanting to do.
All I can suggest is these two things:
Go to a local printing shop and see if they can do this for you. I used to work at an Insty-Prints and they could do thermographed ink (which means the ink is slightly raised, like you see on some business cards), and probably have white or light grey ink. They may be able to do this for you.
Alternatively, you can print it on your printer, but you'll have to use white card stock and have the printer print all the black (and leave the white areas white). This will use a lot of black ink so if you have a lot of these to print, it might actually be easier and cheaper (considering the cost of ink) to again go to a print shop in your area.
That would require a very special "white ink" print cartridge for your printer. The regular color ink cartridges won't do this, since they can only make the black paper "black-er" when it prints ink on the paper.
You may want to ask the manufacturer (Canon) if they make a special "white ink" cartridge for that printer, or know of someone who does.
Your only other option is to make a "negative" print image in Photoshop, or a similar graphics software application, and then PRINT the black ink on white paper... which will then leave everything you want to "print white" as an unprinted area on the white surface of regular paper.
(Note: with such heavy printing you would want probably want to use a heavier grade of paper, such as 28# or 60#.)
This will use a LOT of ink, but it may be the only way you can accomplish your goal.
Hope this helps...
