Sharp R-1480 Microwave Oven Logo
Posted on Jul 24, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Oven does not heat food
Electronics work. Oven can be set for times heating, but food will not heat
Anonymous
Level 3:
  • Sharp Master 43,501 Answers
  • Posted on Feb 25, 2011
Anonymous
Sharp Master
Level 3:
Answers
43501
Questions
0
Helped
10845732
Points
101584
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
  • Anonymous Oct 29, 2011
    We are DIYers and need someone to answer the "doesn't heat" question with more than "call a technician". Times are tough, money is tight, I am good with my hands and can read techical documents, give me the tools to fix the unit! Since the unit is under 5 years old, Amana will give me the part for free, so I need to verify the source of the problem and replace the part. Can anyone tell me more than call a technician at $100 plus for the trip charge?
tip
Microwaves and how they work. ­T­he microwave oven is one of the...
Caption
--> ­T­he microwave oven is one of the great inventions of the 20th century -- millions of homes in America have one. Just think about how many times you use a microwave every day:
Caption
­You're running late for work, so there's no time to fix breakfast at home. On your way to the office, you stop to gas up your car. Inside the quickie-mart, you grab a frozen breakfast burrito and pop it in the microwave on the counter. Later that day, you have to work through lunch. By 3:00 p.m., you're starving, so you grab a snack-pa­ck of microwaveable popcorn from the vending machine and pop that in the break-room microwave. That night, after a really long day at work, you're simply too tired to grill out, so you dish up last night's lasagna and heat it up in the microwave...
As you can see, microwave ovens are popular because they cook food in an amazingly short amount of time. They are also extremely efficient in their use of electricity because a microwave oven heats only the food -- and nothing else. In this article, we'll discuss the mystery behind the magic of "meals in a minute" with microwave cooking.
­A m­icrowave oven uses microwaves to heat food. Microwaves are radio waves. In the case of microwave ovens, the commonly used radio wave frequency is roughly 2,500 megahertz (2.5 gigahertz). Radio waves in this frequency range have an interesting property: they are absorbed by water, fats and sugars. When they are absorbed they are converted directly into atomic motion -- heat. Microwaves in this frequency range have another interesting property: they are not absorbed by most plastics, glass or ceramics. Metal reflects microwaves, which is why metal pans do not work well in a microwave oven.
Microwave cooking ­You often hear that microwave ovens cook food "From the inside out." What does that mean? Here's an explanation to help make sense of microwave cooking.
Let's say you want to bake a cake in a conventional oven. Normally you would bake a cake at 350 degrees F or so, but let's say you accidentally set the oven at 600 degrees instead of 350. What is going to happen is that the outside of the cake will burn before the inside even gets warm. In a conventional oven, the heat has to migrate (by conduction) from the outside of the food toward the middle. You also have dry, hot air on the outside of the food evaporating moisture. So the outside can be crispy and brown (for example, bread forms a crust) while the inside is moist.
In microwave cooking, the radio waves penetrate the food and excite water and fat molecules pretty much evenly throughout the food. No heat has to migrate toward the interior by conduction. There is heat everywhere all at once because the molecules are all excited together. There are limits, of course. Radio waves penetrate unevenly in thick pieces of food (they don't make it all the way to the middle), and there are also "hot spots" caused by wave interference, but you get the idea. The whole heating process is different because you are "exciting atoms" rather than "conducting heat."
In a microwave oven, the air in the oven is at room temperature, so there is no way to form a crust. That is why microwavable pastries sometimes come with a little sleeve made out of foil and cardboard. You put the food in the sleeve and then microwave it. The sleeve reacts to microwave energy by becoming very hot. This exterior heat lets the crust become crispy as it would in a conventional oven.
on May 07, 2010 • Microwave Ovens
Our Panasonic 1350 microwave no longer heats food.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
ghdgh
Viking 1100 watt Microwave will not heat food
heatman101
fjj
My Sharp R-340D microwave works perfectly but Does NOT HEAT FOOD
heatman101
fggfd
1helpful
Maytag Microwave model#MMV5186AA
Typically, no heating of food, indicates a bad Magnetron (tube) or associated components. The oven can be repaired. Magnetrons are not hard to replace and can be ordered online through MCM electronics www.mcmelectronics .
However, due to the dangers of high-voltage within the unit, I would recommend taking the unit to a repair center.
Look in the manual to see what the warranty says. See if there is any information regarding the magnetron or parts. You may be able to get it repaired for free parts, less labor.
Please let me know if I can be of further assistance to you.
Good Luck,
- Jim
3answers
Convection oven problem
Most of the time the magnetron is defective if the food is not heating up.
In some cases there is a defective low power transformer or other componenents associated with the magnetron.
I would suggest to check the owners manual under the warranty section. Sometimes the magnetron has 5 years warranty.
Good Luck.
Top Sharp Microwave Ovens Experts
ZJ Limited
ZJ Limited
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
