Washed load. then started next. code says lid. Have tried closing lid again. Hit start and it makes a clicking sound, even after being unplugged (approx. 15 seconds.)
Re: Code says lid. Tried to restart. COuld it be out
You Door lock is broken or malfunctioned and needs to be replaced. Problem with parts these days is you can repair then you have to replace the whole part (part # W10059230) order it and replace it or call a service technician
Hi Peter, If I understand your question correctly, you are asking what the code "HD" means for your machine. I am unable to find the code "HD", however, here is a list of the codes for these Maytag models, perhaps one looks similar to "HD". Hopefully this answers your question!
Washer displaying code messages
- "LF" (Washer is taking too long to fill)
Check the following:
Are the water inlet hoses kinked or clogged?
Are the water inlet valve screens clear?
Press PAUSE/CANCEL to clear display.
- "Ld" (Washer is taking too long to drain water from the wash tub)
Is the drain hose kinked or clogged?
Is the drain hose installed properly? See "Connect the Drain Hose." Press PAUSE/CANCEL
to clear display.
- "uL" (Unbalanced Load)
If the load is unbalanced, the washer will display this code while running an imbalanced
load correction routine at the end of the wash cycle and before the final spin. If the code
remains and the wash cycle dial is flashing after the recovery routine has stopped, open
lid and redistribute the load. Close lid and press START.
- "oL" (Over Load)
Is the washer overloaded? The washer has attempted to fill and begin the wash cycle. If
the washer is overloaded, it will drain any water and detergent that was added during the
fill. To correct the overload, remove several items and add detergent. Close lid and press
START.
- "Sd" (Suds Detected)
Did you use regular detergent?
Regular or hand-washing detergents are not recommended for this washer. Use only High
Efficiency ("HE") detergent.
Did you add too much detergent?
Always measure detergent. Follow detergent manufacturer's directions.
If excessive suds are detected, the washer will display this code while running a suds
reduction correction routine at the end of the wash cycle. The suds reduction routine
removes extra suds and assures proper rinsing of your garments. If the code remains and
the wash cycle dial is flashing after the recovery routine has stopped, re-select your
desired cycle using cold water. Press START. Do not add detergent.
- "lid" (Lid Opened)
Is the lid open? Close the lid to clear the display. If the lid remains open for more than 10
minutes, water in the wash tub will drain.
- "HC" (Cold and Hot hoses switched)
This code will appear at the end of the wash cycle to indicate that the cold and hot water
inlet hoses are switched. See "Connect the Inlet Hoses."
- "dL" (Door/Lid cannot lock)
Indicates lid is not locked. Check for items caught in the lid keeping it from closing. Press
PAUSE/CANCEL once to clear the code.
- "dU" (Door/Lid cannot unlock)
Is there excessive weight on the lid, such as a basket of laundry? Excessive weight will
keep the lid from unlocking. Press PAUSE/CANCEL once to clear the code.
- "F##" code
Press PAUSE/CANCEL once to clear code. Press START. If code appears again, call for
service.
Take the lid off,just open it & pull it straight up.There should be a little red button that the lid strikes against unless its a different model,in that case it has a magnetic reed switch under the right hand side of the hob.press this red switch instead of closeing lid,see if it fill with no problem.the lid may not be making good contact with switch..if thats not it then it may be the inlet valve..then you can try the hot,if theres no problem with hot then its the cold valve.
we ran into this problem with ours too. I swear, this washing machine is the biggest piece of junk I've ever bought.
We used to get the LD code at the beginning of each load of wash. We solved this by manually holding the lid down tight until the lock mechanism clicked in place. Once locked, it should stay that way for the duration of the wash cycle.
One day, it just stopped giving us locking problems.
For the FAV6800A the od alarm means the Control Board has not seen a lid open condition for three complete wash cycles. I suspect the left lid lock. I think you have a problem with the magnetic reed relay in the left lid lock.If you could try this?I want to make sure you signal an “OP” alarm to the display. Can you select Spin Only cycle with the lid open press start. Do you signal the “OP” alarm lid open to the display? If it does close the lid and the “OP” alarm should clear does it? I’m checking that the lid magnet is in place and the signaling connections are working thru the left lid lock back to the control board. Let us know what you fin and we will go from there.You could try powering down the machine by removing the 120VAC power cord from you wall receptacle.That may give you three more wash cycles before the od alarm is triggered again.
LS Lid Switch Error The control should flash this error code if it cannot detect the lid switch opening and closing properly. This error code may also be used if there is a disagreement between the motor and machine controllers on the stat if the lid switch. The control should not allow the unit to run in this condition. This code will also appear if the user presses the START key while the lid is open. Open the lid or press STOP/CANCEL to clear the display.
Well I have the same problem the only way I have found that my washer works is that on the soiler level make sure you put that on the heavy. And that should work I know its a pain but thats what I do and my washer washs with out stopping
Code LS=Lid Switch. I had the same problem and found that if you pressed down firmly on the lid when closing I would not get the LS code. An uneven load will sometimes cause enough vibration to the lid to stop the washer and display the LS code again. Just lift lid and press down firmly again and start. Eventually I will open it up and adjust the switch.
