Numark BATTLE PAK v.4 Turntable Logo
Posted on Apr 22, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
NUMARK TT 1625
MY HUSBAND PURCHASED A NUMARK TT1625 FROM A PAWN SHOP & NEEDS TO REPLACE THE NEEDLE. WHAT NEEDLES ARE COMPATIABLE OR WHERE CAN HE FIND ONE?
  • Anonymous May 07, 2012
    u can buy the next up grade
    numark cc-1, for me is been the best of the price and service..
    any were from $50 - $80 depending were u live at!. but for the price is a great quality and sound.. so spend that extra dollar and have fun with ur records..
    paz amour muxic dj nero one..
Anonymous
Level 2:
  • Expert 515 Answers
  • Posted on Jul 15, 2008
Anonymous
Expert
Level 2:
Answers
515
Questions
0
Helped
292973
Points
647
Any of the following cartridges will fit your turntables:
CARTRIDGES @ 1200s.com
I don't suggest using the originals that came with the turntables, as they aren't of the greatest quality. For a small investment (about $50), you can get some better quality cartridges/needles.
- Davis
DJ Pro Audio
www.DJPROAUDIO.com
www.REPAIRNYC.com
1helpful
The plate on my numark tt USB is wobbiling
I find it hard to believe some of these answers. If the platter is wobbling, if you remove the platter, you'll find the spindle the platter rotates on. That will probably be loose. At the bottom of the spindle bearing, you will find a nut. Tighten that, and you should be in business. If you have further questions please visit my website at audioserviceclinic.com. You may contact me there.
Numark needle broke
Generally yes. Just type the cartridge number into Google and it should find the right stylus - not needle!!!
2helpful
How do i hook a numark tt 1625 turntable to a regular home stereo amplifier...does the ground need to go into anything specific?
Turntables require a special input in the amp (usually marked PHONO) because they require high gain and different equalization - and yes, that ground wire has to go to ground unless you want to get a super annoying 60Hz hum from it!
If your amp doesn't have a phono input, you're going to have to go out and get a phono pre-amp and connect it between the turntable and the amp.
Best of luck!
I have numark tt 1610 decks, checked needles on both decks and they are both fine 1 of the decks however keeps skipping even when I try with both needles and different vinyls I've taken the weight off,...
Examine the cantilever very carefully - you sure that the stylus is there? Not uncommon for the lever to be perfecto but the stylus is gone. So when you go to play a record the arm slides all over the place!
I can't find a needle/cartridge for my turntable, it's a Numark TT-1910
if you have the headshell left with the 4 little wires hanging out then you will need a complete cartridge.
turntableneedles dot com/Half-Inch-Standard-Mount_c_49632.html
if you have the cartridge part then it's still good and you only require a new needle. Type your cartridge number into the search window at the above website.
No signal coming from rca output on numark pro tt-1 turntable.
Please recheck all connections from the 'needle' to the end of your hook-up cable. Check with a continuity checker if you have one (volt/ohm meter will do nicely)
When I scratch with my numark tt1625 its very slow to spin again
Try Changing The Slipmats Gemini Slipmats Are More Slippery Than Standard Numarks I Use ThudRumble Frosted Plates In Place Of My
Original SlipMats On My 1650's
Numark tt1625 keeps on jumping
If your weight and such are correctly set, then the only other issue might be a worn stylus, or your tonearm might be damaged.
- Davis
We are the Turntable Experts!
DIGITAL ANALOG THERAPY
1helpful
2answers
My numark tt1625 turntables keep slowing down
If you could be a little more specific, we might be able to help you out better.
Does it slow down, when you do anything, or after a long period of time of being on/used? Or as soon as you turn it on, it slows down?
Any specific information would be greatly appreciated.
- Davis
DJ Pro Audio
www.djproaudio.com
Top Numark Audio Players & Recorders Experts
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
Are you a Numark Audio Player and Recorder Expert? Answer questions, earn points and help others
