After I updated my RouteSmart powered by NDRIVE, the update dit not finish and the device only start up to the welcome screen and nothing further. I pressed reset and still the same. What can I do ?
SOURCE: Navman iCN 550 GPS frozen on start up screen and makes a noise like it is stuck
Try hitting your reset button if you haven't already. I had the same problem and this worked for me.
SOURCE: como usar mi gps ndrive ?? no entiendo nada donde
Hola, en el siguiente enlace hay tutoriales de video de como usar los productos ndrive, por el momento solo estan disponbles en ingles, pero con estos tutoriales puede ser mas facil aprender el uso del equipo: http://www.ndrive.com/en/pages/customercare#
SOURCE: how do i update my
After registering your device on the http://www.www.n-drive.co.za website, you will find the "continue download" option. Follow instructions. If you have already registered your unit, go to "Downloads" - "Updates" and follow instructions. (Use a USB cable to connect your navigator to a PC). This should take care of your issue. Let me know if this helped you. Good luck
