Can I use a Belkin f5d8231 as a wireless access point... I need it to comunicate wirelessly to my main router and allow me to plug a network device into it to join my network (i.e. TIVO)
Using Wi-Fi Protected Setup
WPS uses WPA2 (described below) for encryption. It does not
provide additional security, but rather, standardizes the method for
securing your wireless network. You may use either the Push Button
Configuration (PBC) method or PIN method to allow a device access to your wireless network. Conceptually, the two methods work as follows:
PBC: Push and hold the WPS button located on the back of your
Router for three seconds. Then initiate the WPS procedure on the client device within two minutes. Refer to your client's documentation on this procedure. Pushing the PBC button will automatically enable WPS. The client has now been securely added to your wireless network.
PIN: The client device has a PIN number (either four or eight digits)
that is associated with WPS. Enable WPS through the GUI shown
below. Enter the client's PIN into the Router's internal registrar
(accessed through this GUI). The client will be automatically enrolled
into your wireless network within two minutes.
Pretty sure you have to have at least one router in gateway mode to connect to the internet. An AP allows wireless devices to connect to a wired segment. The same as a router in gateway mode. AP mode has the benefit of extending a networks wireless range. If this is your only device leave it in gateway mode.
You can Convert the Router as an Access Point But your Wireless Modem Should Be Hard wired to router. But if your Router has an wireless Bridge Option in it you can Convert it as an Range Extender. Check For the Wireless Bridging Feature on your Router or Please Post your Router's Model Number Here. I Will Be Glad to Help you out... :)
Check the main computer you set up the network router with...you may need to go to the network status and tasks in control panel...click on this...then you will see a map of all the network devices connected...find the belkin router and click on it...in this window there should be a tab called wireless properties..click this...the wireless properties first page should have the wireless SSID name listed here...and if you click the security tab then the security type and network key are displayed here..You need to write down the SSID, security type, and network key and make sdure the toshiba laptop setting for the wireless network are exactly the same. There may be a link on the first page of the wireless securities saying copy to usb drive..you can use this to copy all network settings to and then transfer these settings in to the toshiba by using the network setup wizard.
If you are having trouble connecting to your router wirelessly it is possible that you have your WEP security turned on. The link below will show who to check your WEP setting.
For Belkin Range Extender, it will depend on how you are going to use it. If you are going to use as a "Wireless Range Extender", there is a push button on the device that will allow it to find wireless signals and configure itself with the wireless settings of the original access point on your network.
If you're going to use is as a "Wireless Access Point" you just simply need to plug it in to your wired router or switch.
You don't need software for the router. Is your wireless encrypted or open? Just view avaiable networks with your xp machine and choose your network to connect to. If you do have an encrypted signal use the vista machine and type in the ip address to the router in your browser window. I think belkins router ip is 192.168.2.1 or 192.168.0.1 Hope this helps, let me know
