Televison & Video Logo
Posted on Jul 22, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Motorola VIP1200 set top U-verse converter and a display with SVGA and HDMI. The VIP1200 seems to have a couple of connection options (S-video and a HDMI port). Is connecting them simply a matter of getting the right HDMI cable?
Jim Goldsmith
Level 3:
  • Televison & ... Master 2,005 Answers
  • Posted on Jul 22, 2010
Jim Goldsmith
Level 3:
Answers
2005
Questions
Helped
736130
Points
6152
S-video is only an enhanced picture (video) signal and, must be used with two rca cables: red=left channel sound, white=right channel sound.
HDMI requires an HDMI cable from a HDMI capable (must have an HDMI connector ) cable / satellite receiver to a HDMI TV (also must have an HDMI connector.
Connect my msi all in one computer to tv with vga/svga video cable
Assuming your TV is HDMI input only you'll need a converter.
Once you've installed the converter it will be very easy just plug them together set your TV's input to what ever HDMI port you've plugged in. on your PC desktop rightclick go to properties and enable the second display.
http://www.amazon.com/s/?ie=UTF8&keywords=vga+hdmi+converter&tag=mh0b-20&index=aps&hvadid=3482721557&ref=pd_sl_44liqj4bpp_ee
Need to program a all in one remote to an AT&T U-verse box. The cable box is a Motorola VIP1200.
If you wish to get more, try the following links. Both the sites linked have set-up code list & set-up procedure to many popular brand remote controls. Surf the sites with patience.
http://electrohelponline.blogspot.com/
http://electro-medical.blogspot.com/
I have an aspire one laptop and a video convertor.
Are you connecting the svga out of the laptop to hdmi of tv via a converter? This set should have an svga input on it. try connecting this directly to svga on computer. Computers and converters and hdmi inputs on tvs are always a challenge. Newer laptops have hdmi outputs on them and are seem to work better.
When I connect my Advent laptop running windows 7 to my panasonic viera tv via hdmi via a vga to hdmi converter I just get a blank screen, are there laptop or tv settings that I need to change? Chris.
Yes there are a couple of settings which you must change in order for your computer to register your external monitor. on the desktop right click with your mouse and go to personalize, once that opens on the lower left corner click on display, now on the top left corner about the (5) fifth option it should say change display settings, click there. If you do not see two monitors displayed, click on detect, and once you see two monitors click on apply. Now if you want to extend your desktop to the second monitor simply go to the multiple monitor drop down menu and click on extend these displays, and viola there you have it. Be aware these settings are only meant for Windows 7.
Connect to a set top box with HDMI?
You should be able to connect. I don't have a Motorola vip 1910 exactly but I did a little research and it seems like you should be able to no problem. I set up <a href="http://netplasia.com">hdmi video cards</a> and it was fairly simple.
1helpful
Yes. You will need a HDMI to DVI-D converter or cable to connect them. Be aware that you won't have any sound though as the monitor (unlike flat panel TVs) hasn't got any built-in speakers.
2helpful
Normal Picture Mode Not Available With Cox HD-DVR (Motorola DCH3416) and HDMI Cable
With an HDMI cable connected, the cable box determines the picture size. The settings on the cable box must be changed in order for you to get the correct picture size. I have some experience with Motorola cable boxes; usually to access the settings you turn the box OFF and then press the menu or settings button on the box to bring up the display menu. Hope this helps!
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
