You will have to reinstall the printer/scanner drivers (check on the internet for your type/model and download the drivers if you can't find the original install cd). Usually the HP website is your best bet for old or new driver sets. Source(s): http://h10025.www1.hp.com/ewfrf/wc/produ? Hope it works.
SOURCE: HP deskjet F4140 Error light on & I can"t print
please reset your printer. turn off your printer, leave it for 30 sec and turn it on again....
If you still have problem try to re install the catridges again, follow below instruction
http://etech.maiila.com/hp-deskjet-f4140-all-in-one-printer-catridges-installation
Good Luck
SOURCE: my hp deskjet f4140 will
same thing happened to me: try this fix
1. open HP photosmart essentials
2. go to the 'get images' blue box location on the view tab
3. click 'from scanner'
4. follow the directions
hope this helps - the printer isn't as useless as i first thought.
cheers.
SOURCE: My HP Deskjet F4140 All-in-One won't scan.
You need to have the printer in the ready state
Just do onething ....... take out both the cart and then insert just one cart and try ... check with only color or back one in the pinter
SOURCE: my F4140 won't scan
u can try scanning from Ms paint .. on the file click on scanner and cameras
if that also does not work you will need to reinstall the all in one
SOURCE: my hp deskjet f4140 is not scanning. I press the
i fix one whit the firmware upgrade of the printer
If you need more help come back.Post /
thumbs / testimonial are
welcome!
