Here is a tip that I wrote that will help you with your dishwasher not draining problem...
DishHow do you drain the dishwasher. the bottom is - 2_bing.gif src="/uploads/images/2_bing.gif" alt="2_bing.gif" class="h_mi" /> Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
SOURCE: dishwasher will not drain water out
if plumbed in under the sink, check the spigot the drain hose goes to is not blocked - a common problem. if on drain you should be able to hear the drain pump working. if you hear a faint humming noise instead, then there is probably a foreign object stuck in pump. also check for blockage in the drain hose
SOURCE: dishwasher not draining
try pressing the cancel/drain button.Do you hear water draining into sink freely?? if not i would disconnect drain undersink look for a clog right there first
