Suspect you do not have the cannon scanning software installed.
suggest downloading the drivers from cannon
https://www.usa.canon.com/internet/portal/us/home/support/details/printers/support-inkjet-printer/mp-series/pixma-mp210?tab=drivers_downloads
Then hopefully the program for scanning is installed.
and it works out how your scanner is connected to your pc ?
SOURCE: Scanner command invalid in current state
I have not used CapturePerfect 3.0. Hope the scanner is just fine. Try count only mode to check if it is okay.
Uninstall Captureperfect. Run chkdsk/scandisk to check if OS is ok. Reinstall Captureperfect again and it should work.
S. Mohan
SOURCE: Canon Mp 210 Scanner printer
go into administrative tools click on services and make sure windows image acquisition (WIA) is on manual
SOURCE: I cannot scan to my computer from the Canon MP210
The scanner uses different drivers, so that could still be an issue.
Please go to the canon support site for your printer here, search "scanning" and choose from the results the "error: cannon communicate with scanner." You'll see a series of links like the following, with detailed instructions to resolve this problem.
Issue: ERROR: Cannot communicate with scanner...
1.
Connect the USB cable directly to a USB port on the computer
2.
Disconnect and reconnect the USB cable to ensure a secure connection
3.
Disconnect other device and reboot computer
4.
Press the ON/OFF button to power on the multifunction device
5.
Search for USBSCAN.SYS to install scan driver
6.
Start the WIA (Windows Image Acquisition) Service or Stimon
7.
Uninstalling / reinstalling the MP210 drivers (Windows)
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
SOURCE: scan document as pdf on a Photo 926
open adobe acrobat..not reader, has no ability to create pdf's, and go to file, create pdf, from scanner
Don't forget to rank the advice!
http://www.aa1consulting.com
SOURCE: Setting PDF as default scan setting on Canon Imagerunner 3035
Additional Functions (hardware button on the panel)
Communication Settings
TX Settings
Scroll down to 2nd page
Edit Standard Send Settings
File Format: PDF
Scanning Mode: Black 300dpi
