Please click here to download and install the full-feature software driver and then try scanning. Make sure that the USB cable is disconnected before installing.
Kindly install the scanner software for printer the driver software cd just re install it will install the scanner software and make sure in device manger there is not other usb device listed if it is there just remove it. And refresh it in will automatically install the driver.
During a V.34 transmission, the local machine is unable to connect (handshake) with the remote machine and is consequently unable to send a T30 frame. This occurs when the line is disconnected or if line conditions degrade during the session.
Solutions
Remove any pass-through devices from the phone line, and then try the fax again.
Confirm that the fax/phone cable is no longer than required, and that it does not pass near unshielded electric motors such as fans, heaters, or household appliances.
Try to send the fax at a different time when telephone line conditions have improved.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Hi, This solution is for "older" R-series All-in-One's but it may be your solution as well. You may be experiencing a situation in AllN1's called "SCANNER SYSTEM FAILURE" where the scanner bulb may be weaker than it appears by naked sight and doesn't meet system power requirements to "pass" as good to go and thereby is passing to the printer a failure condition. In the R-Series AllN1's the ultimate solution was a bulb replacement. Which surprisingly is not as intimidating as it may sound if you might want to tackle the problem on a do it yourself basis. I can give you more details if you would like. I think you can respond to this Solution; I am new to this forum. If you can not respond directly my email address is [email protected].
