All aspects of this washer work except for the control panel flashes LE... the door stays locked and the drum won't spin...any suggestions as to what we need to do to fix it? The machine is 7 years old and I have never had a problem until now. Thanks!
LE code stands for locked motor error. When this error code appears in your front load washer it indicates a fault in the motor unit.
1 . Check the connections to the Coil/Stator at the rear of the unit possibly it should be something like a broken wire.
2 . Coil/Stator Assembly will be defective preventing the drive to operate.You should go for a replacement of that assembly.
Thank you !!
Washer Not Filling:
If the appliance is not accepting input from the control panel, follow the steps below to reset the control:
? Unplug machine
? Remove the (2) screws holding center panel and remove panel
? Remove the (1) center screw holding the top panel located inside compartment above washer
? Remove the top panel to expose the door latch assembly
I hope this helps you.
