Question about Sharp 13VT-R100 13 in. TV/VCR Combo
I have a sharp tv/vrc combo without a remote. I'm using a universal remote but wont let me get into the menu. I need to change it from cable to air. Can someone help?
    New Friend:
For sharp TV-VCR Combo with universal remore control,
1/ Start by pressing SET & TV at the same time, the LED goes solid RED
2/ Press 009 or whatever code works for your TV.
3/ Confirm that you can now use your control to flip channels..
Then,
4/ Just press the blue button 2-/12. That allows you to change from cable to air and vis-versa. Hope that helps.
Ade
Posted on Nov 23, 2010
6ya staff
SOURCE:
I have a mitsubishi tv model cs27200 and I dont have a remote. I got a universal remote but it wont bring up the menu. I need to program the channels for cable. I only get local channels without bringing...
You would need to look up how to program that remote to your specific tv. I would look up the owners manual if you dont have it for the remote...and follow the instructions for it. However, you will have to directly use the tv to program it to the cable. The universal remote will only change the channels and volume for you. Use your menu button to bring it up, make sure its set to cable and not antenna, and use your channel + and - to navigate through the menu and vol + to select your option
Nov 20, 2010 | Televison & Video
Tip
Acessing Menu with universal remote
We used a One4All model URC3021BOO remote. We programmed BOTH the TV function and the DVD/vcr button with code 0807.  To access the menu PRESS TV then MENU button then DVD/VCR button will allow you to change menu functions using left and right and select buttons. *TV button will access Menu screen BUT NO menu functions. * DVD/VCR button will NOT access menu screen but WILL control menu functions if menu is already displayed. May work with other sharp products, or other universal remotes? These original (RRMCG1330PESA) remotes run 38.00+ to buy new so try this FIRST!
on Oct 29, 2008 | Sharp 13VT-J100 13 in. Combo
Any way to access on-screen menu on Sharp 13F-M50 without remote
try ebay with the model number; I had the same thing with a sharp set I own---only way to access the menu and do things is with an original remote--if this was helpful please vote for me.
Aug 08, 2009 | Sharp 13VT-K100 13 in. Combo
Phillips 19 inch TV/VCR combo --no remote--can't change channels
I cannot be sure of the exact model but... Press and hold the TV's volume up and volume down buttons simultaneously. On many older televisions, this opens the device menu without the use of a remote. Otherwise, use the menu button, which you can navigate in a similar fashion.
Also, somewhere should be an input button. Press it multiple times times to switch between various inputs (the input must match whatever input you are using). Usually after these menus are opened you can use vol up vol down to change things.
Jul 13, 2017 | Philips CCC193AT 19 in. TV/VCR Combo
Sanyo ds 27510 tv no remote want to setup my tv with an antennea,wont switch from video 2
If it has a MENU button, press it and use the volume up and down to manipulate the choices, press menu again when you get to channel setup. you want AIR if using off air or Cable for cable. Next screen should say start and press menu again, the channels will start to cycle. If htat doesnt do it, you have a new model than the one I just did tonight. OneForall remotes will probably not have the setup button you need to autoprogram. Best bet is to find a Sanyo made universal remote or other Sanyo remote on Ebay as alot of the buttons are proprietary to manufacturer. Some TV's are useless without their own remote if not on a external tuner (cable SAT or digital)
May 13, 2009 | Sanyo DS27510 27" TV
TRYING TO SWITCH FROM CABLE TO AIR
try to use the buttons from the TV.
Jan 29, 2009 | Sharp 13VT-N100 Combo
How do i switch from "air" input to cable input on a 13 in sharp tv/VCR combo unit
Hi
It will depend on your input set up but Page 13 of the user manual should help, if you do not have one try www.usermanualsguide.com/sharp/televisions/13VT-R100_R150 and download one.
Oct 23, 2008 | Sharp 13VT-R100 13 in. TV/VCR Combo
Need a replacement remote converter for my sansui tv/vrc combo
Call the customer service number on the back of the set to see if the remote is still available.
Oct 12, 2008 | Sansui COM1912 19 in. Combo
No remote specific to Sharp combo unit..how to turn off closed captionning
on some models the menu button is on the front disguised as the volume up/down or channel up/down buttons. you have to push both up/down buttons on either one of these to bring up the menu.
Apr 24, 2008 | Sharp 13VT-K100 13 in. Combo
The universal remote does not bring up the menu so I can program all the cable channels in it. I don't know what to do. It is only receiving non cable channels. Help me so I don't have to keep watching...
alot of universal remotes dont let you program your tv with them due to how much more mem they would need. you have to use your actual tv remote or do it manually with the tv. sorry
Jul 29, 2007 | Sharp 13VT-R100 13 in. TV/VCR Combo
Sharp 13VT-R100 13 in. TV/VCR Combo Logo
609 people viewed this question
Top Sharp Televison & Video Experts
Ekse
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
