Asus P5KPL-AM SE motherboard.. chassis intruded... fatal error.. system halt...
the bios setup has no properties to disable the intrusion...also no jumper setting and no button to disable the intrusion in the motherboard...... how to fix this...
If your case is not setup for chassis intrusion, the motherboard has dropped a jumper.
The location is by the last PCI slot between the CD audio connector and the USB bus plug. (it is right next to the CLRTC jumpers)
Good luck
Hello download a manual here at ASUS:
http://www.asus.com/Motherboards/Intel_Socket_775/P5KPLAM/#download
First select your windows
Then select manual and hit global for download
Unzip the file before you can read it
You probably need a Pdf reader
Yes the bios have a setting for this READ THE MANUAL
The chassis intruder is a safety precaution
To prevent unautorized access to the mainboard
when the case is opened (a contact does this)
The wire can be removed from the mainboard
And the settings can be set off in the bios.
So the problem doesen`t shows up again.
Good luck
