DISH Network ViP722 DTV Receiver / 350-Hours Video Recorder Logo
Posted on Jul 21, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
0521 code on dvr
Dvr stopped working reading code 0521
Anonymous
Level 2:
Novelist:
  • Expert 185 Answers
  • Posted on Dec 25, 2010
Anonymous
Expert
Level 2:
Novelist:
Answers
185
Questions
0
Helped
63287
Points
274
Hello! Daniel Busa with Dish Network I saw your post and would like to apologize for the inconvenience. If you've gotten that error message it may be a sign your hard drive is down. If you reset the reciever by unplugging it and it keeps happening you will need a replacement.
The heater runs constantly, the thermostat seems to work, I check continuity through it, it opens and closes. What else could cause not to shut off?
QMark MUH (0521) Compact Heater Wont shut off ... - Fixya
www.fixya.com > ... > QMark > QMark MUH (0521) Compact Heater
QMark MUH (0521) Compact Heater, wont shut off related issues. Get free help, solutions & advice from top QMark experts.
QMark MUH (0521) Compact... Repair Questions - Fixya
www.fixya.com/support/p437492-qmark_muh_0521_compact_heater
Recent QMark MUH (0521) Compact Heater questions, problems & answers. ...thermostat on and contactor makes buzzing noise, fan dont run but its not seized it willfreewheel when you spin it ... How do I turn off my q mark wall heater there.
QMark MUH (0521) Compact Heater Shut - Questions - Fixya
tip
DISH VIP612 Program AUX Remote Code 2
DISH Solo DVR VIP612 Program AUX Remote Code
Would you like to program the Universal Remote that came with your Dish Solo DVR VIP 612 to control your receiver, tuner, stereo, second TV or second VCR using your remote's AUX mode? (Instructions to setup a primary TV or a VCR are a little different, but can be found here.)
To setup your Dish Solo DVR VIP 612 Universal Remote, follow these steps to enter the remote control codes to control a device with the AUX mode:
  1. Turn the device you would like to control on.
  2. Find the brand name of the device you would like to control in the control code tables on page 112 of the Dish Solo DVR VIP 612 User Manual.
  3. Press and hold the AUX mode button until all the other buttons light up, and then let go. The AUX mode button will flash.
  4. Press 0 for a TV, 1 for a VCR, or 2 for a receiver, amplifier or tuner.
  5. Enter one of the three-digit codes from the tables in the manual.
  6. Press POUND (#). The mode button will flash three times.
  7. Press POWER to turn off the device. If the device does not turn off, skip to step 9.
  8. Turn the device back on and try some of the other buttons to make sure they work. If the code works, stop here.
  9. If the code didn't work, repeat steps 3 through 7 with the next device code from the tables in the manual.
Your device control codes for your amplifier or other AUX device are now programmed into your DISH Solo DVR ViP 612.
Now you probably want to set your Dish Solo DVR VIP 612 Universal Remote up so that it always controls the volume of your stereo, rather than of your TV, regardless of whether it is in SAT, TV, VCR or AUX mode. Help for this remote control programming can be found here.
(Help for programming a TV or VCR using the TV or VCR mode buttons can be found here.)
I hope that helps.
________________________________________________________________
DISH Solo DVR VIP612 Manual Download
DISH Solo DVR VIP612 Quick Reference Download
DISH Solo DVR VIP612 Remote Code Scan
DISH Solo DVR VIP612 Program TV VCR Remote Codes
DISH Solo DVR VIP612 Program AUX (Stereo/Receiver) Remote Codes
DISH Solo DVR VIP612 Amplifier Control
DISH Solo DVR VIP612 What Is Limited Mode
DISH Solo DVR VIP612 Change Limited Mode
on Jul 05, 2010 • Televison & Video
tip
I hope that helps.
on Jul 05, 2010 • DISH Network ViP 612
The code for a philips t.v the 1103 code dont work
Hi Tina,
You may want to try these codes. Hope it helps.
PHILIPS
0807 0022 0020 0422
0122 0222 0322 0002 0520
....... 0919 0521 0621 0430 0247 0901
....... 0402 0408 0109 0210 0310 0715
PHILIPS-MAGNAVOX ..... 0807 0022
I have a JVC tv with a Comcast DVR. Remote provided will not work on DVR.
did you take a look at the manual you should have recvd for your comcast remote control, You need to program your DVR, look in the manual for the 4 digit code and follow the instructions- usually- hold the dvr button on the remote down until it stops blinking- enter the code- (depending on who the manufact is) wait for the button to start then stop blinking, see if that helps
tip
DISH Solo DVR VIP612 Program TV or VCR Remote Code
Would you like to program the Universal Remote that came with your Dish Solo DVR 612 to control your primary TV or a VCR? (Instructions to setup a receiver, tuner, stereo, second TV or second VCR are a little different, but can be found here.)
To setup your Dish Solo DVR VIP 612 Universal Remote, follow these steps to enter the remote control codes to control a primary TV or a VCR:
  2. Find the brand name of the device you would like to control in the control code tables on page 112 of the Dish Solo DVR 612 User Manual.
  3. Press and hold the mode button (TV or VCR) until all the other buttons light up, and then let go. The mode button will flash.
  4. Enter one of the three-digit codes from the tables in the manual.
  5. If you want to program Limited Mode, press 1. If not, skip to the next step. (You can add or remove Limited Mode later.)
  9. If the code didn't work, repeat steps 3 through 8 with the next device code from the tables in the manual.
Your device control codes for your TV or VCR are now programmed into your DISH Solo DVR VIP 612.
Help for programing a tuner, receiver, 2nd VCR, or 2nd TV using the AUX mode button can be found here.
I hope that helps.
Code 0521 is the read out. What does it mean? I cannot find it in the catalog.
P0521 error indicates a problem with the oil pressure and/or sensing system Possible causes: Low oil level or motor mechanical fault
Open or short oil level sensor circuit condition
Poor oil level sensor electrical connection
Faulty oil pressure sensor The most likely cause is a faulty oil pressure sensor/switch Locate the sensor/switch and insure the wiring to the switch is in good condition ( CLEAN nad a solid connection) Replace the sensor
LOCKED DVR
I just bought the CH-DVR 1600 @ Target. This is just a temporary workaround to enable playing of region 2 DVD disks (don't have other regions but believe it will work also), until the real regional unlock is available.
1. Insert the region 2 DVD disk and close the tray.
2. Wait for the "Wrong Region" popup to appear in the upper-right corner of your TV screen.
3. The display on your DRV reads "STOP" at this point and the "Wrong Region" popup has disappeared.
4. Press the number "1" button on your DVR remote and a small input popup will appear in the upper-left corner of your screen.
5. Do not press anything else and the DVR will accept this entry as a chapter # and proceed to this chapter to start playing the movie.
NOTE1: The DVR runs in a somewhat restricted node, e.g. the DVR display still reads "STOP" and some remote functions do not work, such as "Menu". The input numbers correspond to the chapters on the DVD disk, so you can experiment and get to the menu once you hit one of the extra feature chapters with a "back to the menu" link on it.
NOTE2: I’m anxiously awaiting the real unlock sequence, as I tried most of the old ones posted here, none seemed to work.
also try this
-Switch player ON with no disc in the tray. Close tray and press MENU, 1, and 9 on the remote control. A menu should appear with the Region Option. Highlight the Region entry and press ENTER on the remote. Type in the Region you want. (Put 0 for code free) Press ENTER again to confirm choice. Press OPEN/CLOSE TRAY button and put in movie.
1helpful
2answers
PIONEER DVDRW DVR-K17B ATA Device Issue in HP Pavilion DV9500 Lap
you may need to clean the lens of drive with a wet tissu paper, otherwise the drive might gone out of order, need replacement.
1helpful
2answers
Pioneer DVR-K17RS ATA ACER CODE=39
it's windows issue, you just need to edit windows registry.
Follow this step from microsoft:
http://support.microsoft.com/kb/314060
Top DISH Network Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
