I push power button and power LED flashes/blinks but no power coming to laptop.Adaptor is ok but nothing at all when just on battery power.Novice at computing matters but can find my way around with help.What can I do or is it now a dead useless brick? Any help most welcome as don't wanna buy a new one.thanks.
SOURCE: Toshiba Satellite A15-S129 PC Notebook will not turn on
I have the same problem. What I have found with mine is that if I can get the battery to take just a little charge then I can get it up and running. Here is how I do it. Disconnect AC power leave the battery in and start the laptop. As soon as thing start to run I plug the AC back in and it works fine from there on. Now mine is flashing as well now and I have a dead battery and it will not restart. Something I have noticed thought is it appears that the yellow light is blinking a code. This is what I have come up with. I appears to be flashing 323 as the code or could be 2 shorts 1 long then 2 shorts and then 3 shorts.
Anyone know where to find info on these flashing codes.
Thanks
SOURCE: Satellite A100-166 PSAA9E does not charge the battery
Your power controll circuit on the main board is bad, you might need to change that or the entire board itself.. If you can get a technician just to repair the power controll circuit you should be fine. most ppl dont do that cause its difficult. Normally your entire main board is replaced. To fix that i will need to see the board but thats difficult since i am sure you dont live anywhere close to trinidad but i am sure someone close to you will be able to repair it, or your can download your service manual for your laptop and attempt to repair it your self.
SOURCE: led blinking
Hi, this sound that the AC adapter produces owes to itself to which the same one does not produce the sufficient amperage to feed the equipment, that is to say is damage, they must replace it, if once replaced the problem of which the equipment does not power on Battery must try to power on the same one without the battery pack.
SOURCE: Toshiba Satellite A55 Series S1063
The blinking power cord icon indicates that the battery is not charging, or is defective enough that it is overloading the charger. The laptop will not turn on unless it "thinks" the battery is charged enough to operate the computer. Even though you have the AC power connected and your adapter may be OK, it is still possible that:
Larry
