When working with any printer it's inevitable that you'll encounter a paper jam. Below are the steps you'll want to follow when this occurs.
* To manually remove paper pull on the paper with both hands being careful not to tear the paper while pulling it. If you're unable to get to an edge of the paper that allows you to pull it you may need to manually rotate the gears that feed the paper through the printer.
Preventing a printer paper jam
As mentioned earlier it is inevitable that you will encounter at least one paper jam during the life of your printer. However, if you're encountering frequent paper jams following the below steps can help prevent paper jams from occurring.
what happens if the paper tears when you are manually removing it? The cartridge is covering the paper, and I can't get the cartridge to move. All printers used to be able to get at the paper path, but I can't find out how to take this printer apart, to get to the stuck paper. I suspect the reason the cartidge won't move is becuase the paper was misfed, and folded under the cartridge, which is now stuck. We're trying to take the printer apart, and can't figure out how to do it. Where's the manual?
