Has it always done this, or did Fax once work? Sadly, Windows XP Fax has many shortcomings, not the least of which is that it won't work with many modems still in common use. Modem incompatibility is not apparent during installation or the initial setup. It only becomes apparent when you try to send or receive a fax. The Fax Service will dial or will answer an incoming fax but then fail with any of a number of unhelpful error messages such as "Line is busy," "There is no answer," or "Reception error." There will be nothing in Event Viewer to give a clue as to where the problem might lie.
These errors have been nearly impossible to track down. To do so requires enabling both PSS and debug logging of fax transmissions, both of which require fairly extensive registry changes. For the time being, the best advice is to attempt to use XP Fax only if you have a modem that is listed on the Windows XP Hardware Compatibility List and using the latest drivers.
Using a cell phone, call your fax machine to see if the fax answers. If it does answer, then hang up the cell phone and fax. Next, using the HOOK button on your fax, call your cell phone . The cell phone should ring and answer the phone call from the fax. If you do not get a connection between the fax and cell, try these: Check that the phone line to the fax is plugged into the LINE jack on the fax, NOT THE PHONE jack. The PHONE jack on the fax is to plug in a TELEPHONE ONLY. If the fax phone line is OK, go into your fax machines' RECEIVE and SEND settings and make sure they are set up properly (pulse or tone dialing, overseas mode, etc.) Print out the HELP LIST as follows: Press MENU button, then 5 on keyboard, then 1 on keyboard. Go through all the settings on the HELP LIST that apply to your problem. (Send and Receive modes, Ring Delay, Receive Options,etc.) Write down the original settings BEFORE YOU CHANGE ANY OF THEM.
your fax is in tad mode (telephone answering device) press the receive button (next to the start button) until you see fax only on the display this will correct the problem.if you have faxes in memory press the report key for reports, then opt.1 for help list
look for print fax
Just found your post and I'm having the same problem. Everything else seems to be working correctly. I can copy, scan, print and I THINK I can send a fax correctly, I should have called the person and made sure it arrived. However, I cannot receive faxes. I have an answering machine on the line, but it is not plugged into the Kodak Pinter, it is in another room. The answering machine answered the call, the FAX noise came across, but the Kodak Printer never picked it up and printed out the fax. I think I have all the settings correct, but the instructions are not very clear. Do you think I HAVE to have the answering machine plugged into the Kodak Printer? That doesn't make sense, but I might try it.
Call your cell phone from the fax machine and check the caller ID to make sure that it is the correct number for your fax machine. Next, call the fax machine from you cell phone, and make sure the fax machine rings. Problems like these are almost always a phone line issue, not the machine.
