SOURCE: westell router modem hook-up
Well, assuming he isn't trying to use the DSL feature, it's possible to put it into bridge mode and bypass its nasty habit of being a modem itself.
SOURCE: BROKEN ANTENNA
The router comes with an internal and external antenna. Also, it has a detachable one that you can be screw it out. You can check at shopping.com or Epinios.com
SOURCE: using westell versa link 327w unable to use wireless laptop
You may have your ip address set to manual. If it is, change it to automatic settings. This will allow for the airport wireless to give you an ip address. From there the airport's internet page should come up and you should be able to go from there. If it is set to automatic configuration, it may be a problem with the airport's router configuration. Sometimes a router only lets a certain amount of ip clients to be used per day. If that's the case, they may all be used up for that day.
SOURCE: My brother just gave me
The 327w router is distributed by Verizon, an internet service provider. On their website you find tons of info on this model.
Go to the Verizon support page and enter
<westell versalink 327w> in the search field.
Furthermore here some interesting info for you:
Westell versalink 327w Quick Start Guide (700k)
Westell versalink 327w User Manual (10M)
Cheers
Critter
SOURCE: Have new computer, trying to go wireless with
make sure you have the ipx and spx protocol installed on the new computer.
