Minolta F10 BF 35mm Point and Shoot Camera Logo
Anonymous Posted on Jul 19, 2010
Loading film into it.
How do you load the film into the camera?
  • Anonymous Jul 19, 2010
    How do you load the film into a Minolta F10BF
Anonymous
Level 2:
New Friend:
  • Expert 86 Answers
  • Posted on Jul 19, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
86
Questions
0
Helped
15796
Points
219
You pull down on the clip on the side of the camera. That will open the back of the camera. Pull out a little of the film from the canister. Put the canister into the side with the spindle. Put the end of the film that you pulled out over the roller on the opposite side of the camera then shut the lid and turn on the camera.
Trouble loading the film
Should auto load film and wind all the way out, winding back I one frame as a time as shot. The end of the film must be flats (not bent) and placed within the confines of the red line in the film chamber.
if this doesn't work, the phase switch in the loading gear assembly may need to be cleaned. This is not easy, even for a tech.
I have an old Nikon Lite Touch Zoom 100 AF camera and I am having trouble loading the film. Can you use Kodak Advantix APS film in this camera or should I be using manual loading film instead?
This camera uses 35mm film, not APS film. 35mm is a larger format, giving MUCH better results, at the expense of having to manually pull the leader across to the take-up spool each time you load a roll.
Camera repairs
loading mechanism,gear system must be defective,so u r not able to load the film,while loading shutter gets charged,stops running,so the shutter mechnism also be chaqued.
3helpful
What does the blinking E in the Nikon n65 mean?
It means "Film remains in the camera after film rewind complete."
If this is happening after shooting, the remedy is simple: open the camera and remove the film. If this is happening right after loading the film, then you've got a more serious problem: the camera is rewinding the film upon loading.
When i load the film in the back of the camera it blinks "E" and "o _ _" and doesn't move automatically to the first frame
Blinking 'E' means no film loaded. 'o_ _' shows that the film is loading. Apparently the film has not gone to the receiving spool. Pull the film all the way over to the other side when loading the film and make sure it catches the spool.
Feb 22, 2010 • Photography
CAMERA EATS FILM
When loading film, pull it all the way to the receiving spool.
Minolta X-300s film loading problem
Hi -- yes if you cannot advance the transport mechanism ( and so cannot load the film ) this is because shutter is not working ! This a very common problem and is due to leaking capacitor ( 220 microF ) situated on the botttom of the camera. Remove bottom cover and replace the capacitor . You should be able now to release shutter and load your film.
Aug 20, 2008 • Photography
1helpful
Loading film
After further investigation and because I can't keep my hands out of things I now know that the camera body is defective and that the shutter is jammed. It will only release with assistance. I was loading it correctly.
Apr 17, 2008 • Photography
1helpful
Loaded film wrong??
I'm assuming you're not able to shoot pics. Its my best guess that the film just isn't getting loaded properly. Next time you attempt to load film there maybe a small red mark near the take spool (bottom edge where film goes) to indicate how far you need to pull the leader forward toward take up spool. I think the film isn't out quite far enough for the camera to do its auto load thing & when you close the back it goes thru its auto loading motions but the film just isn't getting loaded. Then close back & see what happens.
Top Minolta Cameras Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Tony Parsons
Tony Parsons
Are you a Minolta Camera Expert? Answer questions, earn points and help others
