Big problem with play lists
According to the manual for most GoGear's, you have to have automatic synchronization enabled in Windows Media Player for the playlists to transfer correctly.I still have not been able to verify if this is true, since I have been able to transfer playlists fine with and without auto-sync engaged.
I haven't tried a 3115 specifically, but with an SA4111 and an SA5125, I just created the playlist in Windows Media Player 11, right clicked on the playlist name after it was created, selected "Add to Sync List," and then "Start Sync" with GoGear connected. I used this method, because it seemed more likely to add the songs AS A PLAYLIST rather than just dragging and dropping the tracks WITHIN the playlist.
As I look more closely at the documentation for the SA3115, however, it does not have the same playlists options as other GoGear's - it seems to limit you to Playlist-on-the-Go. I know that the GoGear will not recognize folders that you create in Windows Explorer, so that option is out. You can connect the GoGear, and see if a Playlists folder appears in the left-hand pane underneath the icon of the GoGear in the Sync tab. My gut feeling, however, is that this player is just not as equipped as other GoGear models for playlist transfer. I'll go back to the lab on tuesday and see if I can find anything new.
-Tha Mp3 Doctor
