Luminox Field 821 wristwatch Logo
Posted on Jul 19, 2010
How do I zero the stop watch
How do I reset the stop watch to zero
Anonymous
Level 1:
New Friend:
  • Contributor 10 Answers
  • Posted on Jul 25, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
10
Questions
0
Helped
3669
Points
30
Pull the winder out to either the 1st or 2nd click & use the push buttons to zero the hands in.
How do i change the time on the three small dials
Hello Garrett,
"Three small dials"... My guess is that we are talking
a chronometer... (stopwatch)... "ZERO Process".
Not only are the three sub-dials usually settable... but also the sweep second hand.
Trouble: After resetting the watch... the hands go back to the same position...
Solution: You want to "ZERO" your dials... one by one.
These watches typically need to have the stem out to the third position... then press the top "start" timer button... observe ONE of your dials is moving. As it approaches the desired number release the button and step it into position with single button pushes.
Go to the bottom "stop" button... Repeat the process!
Push the stem in to the middle "set" position...
Repeat the process!
Again... press the top "start" timer button... zero
and finally press the top "stop" timer button... and zero.
Set the time and date... push that stem back into the home position... and record 35 seconds on your watch... stop and reset...
If everything does not come back exactly to ZERO...
Then that is called an iterative process (do it again).
Fine tune it!
Good Job.
(comment me back if I didn't hit the spot)
Horology Wikipedia the free encyclopedia
Feb 10, 2016 • Watches
HOW TO RESET STOP WATCH TO ZERO
What you need to do is to pull the crown to step 2 (full out) and then push the start button. Then the second hand will start moving one tick a time all through the dial. Keep pushing it until you reach to zero.then push crown back in, That's it.
1helpful
Reset to zero stop watch
pull crown out to second position press start till it goes to zero then push crown back in,,,if that doesent work pull out to first position and do the same,,
1helpful
On my new Victoronox 24332, the sweep hand for the stop watch does not reset to zero but rather to about 17 seconds past '12' O'clock. The split second hand also stops just past Zero on...
Follow the instructions on the following link. I believe it works on all or most Swiss quartz chronographs. Worked like a charm for my Mondaine and my Zodiac. Hope it works for you too.
http://mondainewatch.co.uk/my-chronometer-doesnt-go-to-zero.html
4helpful
2answers
Stop watch will not reset to zero
pull the crown full out reset all hands set time set alarm or second time if you wish and press the crown back.
Howe do I reset the stop watch. It will not reset
I went to the lorus web site which has user manuals for all their watches. Went through the relivent manual whcih gave details on how to reset the stop watch facility.
4helpful
3answers
Stop Watch not resetting
pulling the crown out to position 2 and pressing button to zero it out one increment at a time is the way to do it do touch the watch hands. Works on fossil watches as well as tag watches
Top Luminox Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Luminox Watch Expert? Answer questions, earn points and help others
