I cant get my Craftsman Keypad to operate my Liftmaster Control Unit when i try to program in the Learn setup Of my Liftmaster Control ?
Lift-master Model 1160-1/2 HP
Remote Craftsman Model 139-53684I cant get my Craftsman Keypad to operate my Liftmaster Control Unit when i try to program in the Learn setup Of my Liftmaster Control ?
The wireless keypad stops working only when the garage door opener is in the "door full closed" position. I have tried it with the door disconnected from the opener, so it is not the actual door positon that is the problem.The wireless keypad stops working only when the garage door opener is in the "door full closed" position. I have tried it with the door disconnected from the opener, so it is not the actual door positon that is the problem.
AnonymousJul 08, 2008
Garage door keypad light flashing and will not operate door. Remote and inside wall buttons will all operate the door.Garage door keypad light flashing and will not operate door. Remote and inside wall buttons will all operate the door.
AnonymousNov 05, 2008
I need to change the code on my garage door outside. How would I go about doing that?
AnonymousMar 14, 2014
i opened with the remote properly and the doors locks opened but doors dont openi opened with the remote properly and the doors locks opened but doors dont open
AnonymousMar 24, 2014
Forgot code to open door via key pad, how do I reset?Forgot code to open door via key pad, how do I reset?
You can't post conmments that contain an email address.
Assuming, from what I read, the remote works..The inside switch is just a doorbell switch which will wear out or have the contacts get bent or dirty. Take off wall, and change for new one or see if the contacts can be cleaned or adjusted. If the pad is electronic (coded) the wires may be bad or the control defective. Usually momentary contact of the two wires will cause the door to actuate.
It sounds like your keypad is going bad and has a weak signal. It can operate the opener with the door open but with the door between it and the receiver it can't.
I'm confused about the battery you replaced inside the garage but you can try programming the keypad just to see.
Locate the smart/learn button on the back of the motor unit near where all those white wires go. Press and immediately release it and then walk over and key in your 4 digit code and press enter. If this doesn't work and you know the battery inside the keypad is good, you have a bad keypad.
Press and hold for 3 seconds the button on the wall control that has an icon of a lock. The light should quit blinking and your remotes will once again work. Holding that button for 3 seconds toggles your openers vacation mode.
The most common problem for your situation is that the battery in your wallmounted key pad needs to be replaced. unscrew the little screw on the face of the device, remove the battery and replace it with one just like it. Radio shack usually has these batteries
