Have a KDC-215S install in in my Jeep. When the ignition is off, the unit will drain the battery in about 2-3days. Everything is fine when I disconnect the yellow +12v line that provides the constant power. Why does this consume so much power when supposedly is off?
You could add a switch to control the power going to the head unit. I have seen this done in many different vehicles where the head unit drains the battery, even when supposedly off.
check the wire harness connections, sounds like you have KOER power hooked to KOEO. Or in other words, you have power to the radio with the key off that should connected to key on power
Press and HOLD the A.ADJ (Audio Adjust) button for 1 sec. to enter audio control mode.
Step 2:
Press either FM (or AM) button to select the mode you wish to adjust. Keep pressing until you find the mode you require (in this case, it will be BL for Balance).
To change the value, press the Down Search or Up Search button to your desired setting. Centre balance is "0", negative number is Left speaker, Positive number is Right speaker.
Step 3:
Repeat Step 2 to select the TREBLE (TRE) mode, then use Down, or Up keys to change the value.
You can download the complete instruction manual in PDF format by clicking this link.
You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Some decks only give one pair of pre outs. Most 4 channel amps can use just a 2 channel input and feed the other 2 channels by the flip of an input selection switch. I recomend a 4 channel amp if you want to power front and rear speakers and be able to set the gains to blend properly, or you can run all 4 speakers at a 2 ohm stereo on 2 channels and run a sub on the remaining r channels. It just depends on how you want the setup to be nd to how much control you want. Let me know.
The tuner secton has defective components. It is servicable by an experienced tech who is familiar with the model and has the setup to troubleshoot and service it.
Considering the cost of service compared to replacement, I would think it would be best to replace the unit rather than invest in to servicing it.
its the face plate just need to take out clean with little rubbing alcohol these kinda face plates has a scrolling feature that i donot like very much face plate just needs to adjusted back on sterio mount
