Your pressure relief valve may not be working. If that happens when you shut off your spray gun, then pump is dead heading, stopping the motor. If this is the case it stops dead, not coasting. Either replace the pressure adjusting relief valve or remove it, and disassemble it and clean it.
Oil for the troybilt 3000 psi is 4 cycle sae 10w-30
What type of oil do honda troy-bilt pressure washer psi 3000 need?
