I was DJing with my ce 1000 running 1- 18" sub. The amp just quit working. "On" led is on, Green "signal"led is on but I am not getting any sound from the speaker. I already tried another speaker and still no sound. Any advise?
SOURCE: i have a crown ce 2000 watt amp. channel 2 keeps turning off
Do you get any Fault indications?
Have you swapped the speakers around to eliminate them as external causes?
When the channel dies is the unit very hot and is the fan turning very fast (it should be if hot)? The fan could be defective, slow or airflow may be restricted.
Turn the amp off and examine the fan guard on the rear to make sure it is clear of dust and debris. Vacuum it out if necessary. With a small thin non-metalic object reach in and test the fan for free movement by trying to rotate it. It should coast.
SOURCE: got a couple of CE
Hi
Please check this link to download the manual where you will get the related answer regarding your query..
http://www.retrevo.com/support/Crown-CE-4000-Amps-manual/id/22150ag317/t/2/
Let us know if you have somethin more to ask else accept the suggestion.
Thank You for contacting Fixya
SOURCE: I get just a humming
Check out the Electrolytic Capacitors in it. Suspect the largest ones first.
