Well friend,
According to page 24 of the manual here http://support.casio.com/pdf/008/ap_45_e.pdf
It says
Demo tunes While holding down the MUSIC LIBRARY button,
press the PLAY/STOP button
.....and try to play a specific demo tune ........
After playback starts, press the tone button that
corresponds to the tune you want to play.from the list.
ALSO in the Troubleshooting section page 35 For DEMO tunes UNPLUG HEADPHONES
If it doesn't work, then you need to get a Technician to look at it.
Might be best to contact the local service agent in India for Roland equipment.
Rivera Digitec (India) Pvt Ltd,
411 Nirman Kendra Mahalaxmi Flats Compound
(off Dr. Edwin Moses Road)
Mumbai 400011 Ph 022 24939051
You may need to perform a factory reset operation. Turn power off, hold down the DEMO button and turn the keyboard back on. The
screen should display 'Setup is initialising'. This will disappear after a few seconds and the screen will display its default. If that does not work you may need to re-install program disks, I think you should have 6 of them
Remove power supply or battery for 5 minutes. Apply power while holding the on switch in, this usually resets most electronic devices to their factory default condition. Then look again.
It may be your old computer was running XP operating system and your new one Win7... There is a lot of incompatibility with different operating systems. You can try searching for a compatibile driver. If you cannot find one, the best thing might be to back-step to your old compatible OS and driver.
Usually you just select which demo BEFORE starting the demo.
If you are meaning to try to DOWNLOAD via MIDI or other those demo pieces that is USUALLY not possible as the pieces are stored in a ROM which is inaccessible via MIDI or USB.
They OFTEN don''t even send them out on the MIDI port when playing them.
