Cars & Trucks Logo
Posted on Jul 18, 2010
1997 Dodge 1500 club cab - just started running rough today.
1997 Dodge 1500 club cab - just started today on my way to work and it started shaking and running rough. burns oil but I know thats not it as I check it all the time, put new plugs and wires in about a month ago and run fine until this morning! Somebody Help Me Please Its My Only Mode Of Transportation. Thanks Much
Anonymous
Level 1:
Problem Solver:
  • Contributor 10 Answers
  • Posted on Jul 18, 2010
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
10
Questions
0
Helped
2118
Points
25
Take a look at the Harmonic balancer. Has it come apart? How do your motor mounts look?
  • crossfire1 Jul 19, 2010
    Thanks for the info, it was neither one of them. Drove it today and it is running normal again, don't know if something got caught in the fuel filter or one of the injectors. Took it out and run it hard and no more problems, hopefully no more problems pop up. Thanks, Have a Good One!
I need to download either a service manual or a complete wiring diagram for a 1997 dodge ram 1500 5.9L V8?
Fuel pump. I just pulled apart the dead fuel pump from my Astro today. Looking at the motor, it would have to land on one position only in order for it to have restarted as the brushes contacts on 3 of the 8 windings had worn down. Likely you could get the engine to fire if you used starting fluid, but it wouldn't stay running.
1997 Ram 1500 Club Cab: truck overheats very quickly...
Hello Guest and thank you for asking your question, on Fixya.
Here is a simple process that will walk you through a few steps that will pinpoint the overheating problem on your 1997 Dodge Ram 1500 Club Cab, without even using any tools. It has helped millions of people, and I am certain that it will help you, because I wrote it for people like you. So here is the link:
How to diagnose your overheating 1997 Dodge Ram 1500 Club Cab
You might want to pay closer attention to the block test or thermostat sections of these instructions.
Get more great, money saving, tips and tricks about your vehicle from: twitter.com/acoates23234
Thanks for the vote, and good luck!
Do i have adjustable hubs on my 1997 dodge ram 1500 magnum 2 wheel drive
your hubs are NOT adjustable
well.. you could tighten your torsion bars and that will lift the front of your truck up, but i wouldnt recomend it because
1. it is EXTREMELY DANGEROUS. the torsion bar could snap while adjusting it and fling through the cab.
2. Your vehicle will ride extremely rough.
I have a 1995 Dodge Ram 1500 5.2l when I start this vehicle it runs rough until it get to operating temperature, then it runs fine. I have changed every sensor and problem still presist. Also changed plugs...
Did you replace these: IAT(intake air temp) sensor----
CTS(coolant temp) sensor-----
MAF(mass airflow) sensor-----
First things that came to my mind.
Good luck !
97 Dodge 1500 with a pretty bad shaking at lower speeds.
there was an issue with plate on underside of intake coming loose and causing vacuum leaks and rough idle
Top Dodge Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Dodge Expert? Answer questions, earn points and help others
