Question about Toshiba 42H83 42" Rear Projection HDTV-Ready Television
My Toshiba 42H83 (2004) has double (or triple) images. Is this something that can be fixed? Is the repair some sort of lamp? If so, is that an easy fix?
  • Toshiba Master
  • 8,457 Answers
This tv have a problems known as a convergence problems,it dead.The tv convergence booard the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board, must be replaced to solved the tv convergence problems.The shop will cost u $300-350 for parts and labors.
Posted on Jul 18, 2010
6ya staff
SOURCE:
Hi all. i got 1 toshiba led tv 32pb10e problem DOUBLE IMAGE WITH DISPLAYED RED N BLUE COLOR ONLY ON SCREEN . I TRIED REPAIRED SINCE LAST NIGHT BUT CANT . PLS HELP ME IM URGENTLY NEED REPAIR IT . TQVM
The old projector TV's are using 3 lamps for Red Green Blue....in your case the Green lamp stopped working....either the Green lamp burned or the lamp board is defective.
Mar 31, 2016 | Toshiba Televison & Video
Suddenly double/triple images, bowed red at the bottom
Yes, the convergence IC's need to be replaced. If you are not experienced in TV repair, I would recommend getting a qualified repair man to do it for you.
Here is a link with instructions on how to do this, if you feel adventurous:
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Should you find this info useful, kindly take a moment to "Accept" it. Thanks.
Jul 05, 2008 | Toshiba 53H71 53 in. Rear Projection...
How do i fix my toshiba studio 202s,double image result
If you have replaced all that, check your drum cleaning blade and your erase lamps, these two items will contribute for Ghost images "double image". The erase lamps disperse the electrical charge so the blade can scrap the toner off the drum.
Dec 10, 2014 | Toshiba Office Equipment & Supplies
Toshiba e 350 alway stick letter on paper although my rules is well
You may need a new drum cleaning blade or a new upper fixing roller. Both would cause a double image of sorts.... Good Luck
Jan 26, 2013 | Toshiba Office Equipment & Supplies
I'm getting a double image of everything on the screen in a hazy blue colour. I tried configuring the colour within the menu but the cross simply won't line up. touch focus seems to work with the...
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Aug 11, 2011 | Toshiba 57H81 57" Rear Projection...
The picture has a triple image
Very common and easy fix. Install the RCA repair kit called ' ITC222 and ITC222A convergence option missing repair kit. Its available from www.tvrepairworld.com and contains the parts and the CD with repair instructions.
Jul 11, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
My toshiba 42pw33p television show double image
If the convergence controls don't fix the issue then the convergence circuitry is most likely faulty. A Toshiba repair center will be able to get you an estimate for repair.
Oct 31, 2008 | Televison & Video
Double outline "red" around images
Hi you have bad convergence ic stk modules ,Cost for repair center to fix is 250.00. call your local repair center ask there prices on convergence ic repair. It is a very common problem every 3 to 5 years .Our service center does a lot of these.
thanks doctor video 1987
Jun 01, 2008 | Toshiba 42H83 42" Rear Projection...
Double imaging
The Toshiba 55H70 is a standard rear projection set. It does not have a "lamp", it has 3 picture tubes. When the colors suddenly do not line up on the screen, it means that one of your convergence output IC's has burned out and needs to be replaced. This is very common on those sets. If your set is using the STK392-110 IC's, it is probably a good idea to go ahead and replace both IC's with the newer upgraded STK392-150 IC's. The IC's should be replaced and the convergence circuits realigned by a qualified tech familiar with Toshiba projection sets.
Sep 11, 2007 | Toshiba 55H70 55" Rear Projection...
Toshiba 42H83 42" Rear Projection HDTV-Ready Television Logo
298 people viewed this question
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
