I got my display to come on while on the base unit, by making charging contacts connect. When I did this, then battery indicated it was low, then though I had taken it out a working phone. Maybe the fact is one of charging units are not charging correctly if have several. I have a 3 system unit and it is the base that seems to have the problem.
Possible that the battery Voltage has gone BELOW the THRESHOLD level and so will take a long time to come up so that the display light ups. It is best to see if the battery is leaked, damaged or the connectors clogged. Test the voltage on the battery and replace if the voltage is low. Also keep the phone plugged on overnight so that the circuit warms up and clears all disturbances.
Start by swapping the batteries between units. If the formerly bad handset charges, it's a battery. If not, look for dirty contacts where the unit sets into the base or the batteries fit into the holder.
