NTL VS1500 Cordless Phone Logo
Posted on Feb 27, 2018
My NTL DECT model VS 1001 phone has no dial tone
My NTL DECT model VS 1001 phone is not receiving a signal form the base station - I have no manual - how do I retune the handsets - I understand this is also sold as the Binatone bd 3000? Which buttons do I press? The display shows a radio antenna with a question mark next to it.
2 Related Answers
Anonymous
  • Posted on Oct 30, 2008
SOURCE: BINATONE ELITE PLUS MICRO DECT WITH ANSWERING MACHINE MANUAL
I have a Unidan Dect 6.0 and I can't get a dial tone and I can't find my manual.
Anonymous
  • 15 Answers
  • Posted on Mar 01, 2009
SOURCE: NTL VS1003 Cordless Phone Problem
You should be able to download a copy of the manual at :
www.cordless-phones.uk.com
Hope you find the solution there!
I-DECT Phone. It receives incoming calls but won't dial outgoing.
Question edited fir clarity
Ideas here. You can also Google
make model manual
See if it is a an outgoing call barring feature.
https://www.google.com/search?q=I-DECT+Phone.+It+receives+incoming+calls+but+won%27t+dial+outgoing
Cl83123 Dect 6.0 2 phone one started to go bad yesterday. no dial tone won't answer a call won't show me user id, the other phone is still working great what do I do?
My Uniden DECT phone has rechargeable batteries in the handset and the base station has a transformer power supply. The battery may be shot or the transformer may have failed?
After power outage, phone shows time, no dial tone..Uniden DECT 6.0
Unplug the base station / charger for 10 minutes and then plug back in. It may reset. Also, check if the battery in the phone is fully charged. I had a power surge last year and unfortunately, it blew my base station and I had to get a new phone.
I not have manual for Uniden dect 6 cordless phone on my phone I can't get any dial tone,I think I pressed a button on the phone either mute, intercom or redial, how to reset phone
If you have no dial tone the problem is most likely the base station has failed, nothing you can do will kill the dial tone (no button you pushed etc.) except a failed base station.
Phone #2stoped ringing, no sound when dialing etc .
go back to that base station and ensure that it recognizes the bedroom phone
follow the user manual to install other phones
the bedroom phone has to be the same exactly and not earlier versions or different makes
Won't hold a dial tone go new batteries still a problem
Maybe trying to pair the handset with the base station will solve your problem. Look in the manual how the pairing procedure is done for your phone.
If the pairing procedure is done, and the handset finds the base station and there's stil no dial tone, check if the cable from the telephone line is plugged in the base station of the phone and check if the other side of the cable is plugged in the wall phone outlet.
I hope this will solve your problem.
Bell Studio 4500 DECT phone with answering machine: just out of warranty, this phone does everything properly up to entering a number, then dialling, BUT not producing a ringing-tone or getting through to...
I gather you have the setting for tone and pulse set to tone? Also are you aware the ringing tone is generated by the phone company? When you dial a number and it connects, the phone provider sends the ring signal to the dial phone and the ringing signal to the dialing phone. Do you get a dial tone before dialing?
2helpful
I have 2 problems. 1. The orange message light will not stop flashing no matter what I do. 2. Some how the system was switched from touch tone to dial tone. I can't seem to that switched either.
Resetting the voice message waiting indicator
When you receive a new voice mail message, the new message LED on the top of the handset flashes. In the event your message waiting light gets out of sync with your phone company's
voice messaging system, you can manually reset it back to the "No messages waiting" state.
1. Press and hold FiND on the base for five seconds.
Note: The handsets connected to the base will start to beep, however, keep pressing for five seconds.
2. A beep sounds and the message alert tone is reset.
Changing the dial mode
Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most base networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you will need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, please follow the steps below to modify your phone's settings:
1. Press MENU/SELECT.
2. Select the Global Setup menu, and then the Dial Mode submenu.
3. Scroll to highlight Pulse.
4. Press MENU/SELECT. You will hear a confirmation tone.
If you ever need to change the dial mode back to tone dialing, follow the same procedure, but select Tone in step 3.
Finally for future ease of use, here is a link to the user manual were I copied the above information from:
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/DECT1580-3om.pdf
Philips dect 521/525 - 3 year old phone - No dialling tone on one handset
I had the same problem and my hubby managed to reset the phone by simply unplugging it from the electical network. Just wait for few minutes (the date goes back to 1 Jan 2005), then plug it again and try to dial a number. It should work.
Top NTL Lands Phones Experts
k24674
Are you a NTL Lands Phone Expert? Answer questions, earn points and help others
