Sylvania SRC22134 13 in. TV/VCR Combo Logo
Posted on Jul 17, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Sylvania tv/vcr combo, Model# SRC2213X. When i watch a vhs tape my volume works fine but when i watch regular cable all i hear is a popping sound and nothing else.
Anonymous
Level 2:
New Friend:
  • Expert 177 Answers
  • Posted on Jul 17, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
177
Questions
0
Helped
50280
Points
494
Is the cable watched via a cable receiver? If so, you might have a connection issue between the Cable box and the TV
VHS tape not working in Samsung TV/VHS Combo and unable to get the tape out
Must take VCR out to remove tape gently.Cause of problem is usually a dirty mode switch.
I have an old emerson TV/VCR (Digital Tracking VHSHQ) The TV works fine, but when I put a tape in it is ejected and part of the tape stays inside, but can be pulled out.
Try a VHS Cleaning Tape Cassette. Follow it's instructions. If no better result it's not worth throwing away money on having repairs done but better put toward, if you can afford to, buying:
Option 1. A VHS/DVD player (combo as these are known) and plug that into the Emerson AV input.
Option Two: A VHS/DVD twin recorder combo deck - and plug that in.
Then start on copying any VHS tapes you cherish to DVD on this device.
Option Three: Forget the Emerson except for just using as a TV and buy a new TV with DVD player built in - the latest type of combo.
(I'm having to guess whether you've just used tapes to watch or record and watch)
Vcr cuts my tv off after i put the tape in
The VCR is not turning the TV power off. The tape is not playing. I'd guess maybe it needs a cleaning or a replacment.
1helpful
My dvd/vhs combo has sound but no picture on the vhs side?
Check ur RCA cable setting might have a short in the cables.
1helpful
Need code for SRC2213X with Radio Shack Remote (Sylvania TV)
I was having trouble finding a code that worked for my new RCA Digital TV converter box, model DTA800B1, remote for use with the Sylvania SRC2213X Color TV/VCR Combo. I found another site that had a guy saying he stepped through and found code 116 worked. I tried this and it worked for me too! If you are using a 4 digit code, probably 0116.
Here is where I found my help (if you want to see the original post): http://tv.manualsonline.com/ex/thread/view/idThread/777397
Sansui tv
sounds like the tv is on the wrong sorce
2helpful
2answers
Emerson ewc1302 13 in. tv/vcr combo problem
We had that same problem. Try a VHS head cleaner. Worked for us.
1helpful
HELP! I can't figure out how to Connect my Sylvania DVD/VCR Combo to my older TV
Even if you do get it connected you cannot copy from vhs to dvd as you have bought a vcr recorder with dvd player, not a dvd recorder. You can only record to the vcr tape from a dvd, in the players controls.
7helpful
6answers
My Tv is turning off by itself
if all you want to do is disable the vcr portion turn the set on , install a blank vhs tape it has to be blank or the vcr will try to read it .and the tv and dvd should work fine. this is a timing problem in the vcr deck its not hard to fix but it is a pain.
Top Sylvania Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
