Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Re: Mitsubishi Rear Projection TV model #WD52725 LOUD NOISE
Re: Mitsubishi Rear Projection TV model #WD52725 purchased 2005.
Very loud buzzing sound came from area near lamp, not speakers, almost sounding as if a fan was dragging at first, like overheating. Changed lamp & cleaned filter but sound persisted, becoming consistent with no picture/no TV sounds except for buzzing noise. After turning TV off, sound remains for a minute or two, then stops. Any ideas? Nothing about noise in troubleshooting manual. Thank you. Kubbas
5 Suggested Answers
6ya staff
SOURCE:
Slinteriors
Sonny Berry
  • 8617 Answers
SOURCE: Mitsubishi WD52725 DLP
Your DVI Cable may be defective as a 44 code is DVI cable
Posted on Jun 21, 2008
Anonymous
  • 178 Answers
SOURCE: no display or sound on Mitsubishi WD-52725
This is a DLP They have issues with the color wheel, the winding sound could be from this color wheel. If it stops spinning it will cause the tv to shut down. DLP is a mechanical display process. If you are handy and understand electronics you could replace this yourself. If not i would let a tech handle it.
Posted on Sep 02, 2009
Anonymous
SOURCE: Getting a loud buzzing noise in the rear of my
I have just experienced the same issue with my mitsubishi WD62525 as well...thought it may have been a lamp issue as well....replaced the lamp with the spare and still have the same symptoms...(only difference is that my timer light just continues to blink green and never turns red???) I cleaned out the rear filter...was not really that dusty so not sure what else it may be????
Posted on Sep 14, 2009
electronick
thielectronick
  • 505 Answers
SOURCE: My Mits 62"initially has no picture and loud noise until warms up
all of these tvs had bad caps.. that is probably your issue, as they can cause lots of symptoms.
here is my tutorial on this
http://www.fixya.com/support/r5069371-mitsubishi_led_keeps_flashing_green
Let me know if I can be of further assistance.
Posted on Jun 14, 2010
Buzz sound from Toshiba model 72HM195
Mine is doing the same thing. I think its the cooling fan. The bearing is probably gone.
Nov 22, 2012 | Toshiba 72HM195 72-Inch Diagonal...
Loud buzzing and standby/temp and lamp light on
That kind of symptoms indicated that the color wheel is already faulty. Confirm where the buzzing sound came from, if it is in front/near the lamp assembly, then you have to replaced the color wheel to resolve the issue.
Nov 01, 2011 | Samsung HLR5067WX 50" Rear Projection HDTV
I have a samsung hln437n and I have a loud, high pitch buzzing noise which stays on all the time. It sounds like it is coming from the lamp. Any idea what the problem is?
Could be a slightly loose lamp connection and/or slightly loose lamp module - especially if you
have big trucks or railway tracks near your place (like me). Try powering down the TV set, use the
instructions that came with your TV to remove the lamp module, then simply re-install the lamp
module (also known as "reseating the lamp module").
If the buzzing noise persists, then
its coming from a component near the lamp (such as the power supply).
If there's a transformer in the power supply that's buzzing, then its about to fail.
Apr 17, 2011 | Samsung HLN437W 43" Rear Projection HDTV
Makes buzzing sound and no picture lamp?
Buzzing sound is the Color Wheel # BP96-00250A $83.25 Encompass Parts has them in stock 1-800-638-3328 and for Lamp Call FOX 1-800-227-5369 I got my Lamp off of E-Bay $85.00 I have the Same TV.
Dec 24, 2009 | Samsung HLR5667W 56" Rear Projection HDTV
I have no picture. The screen will not come on. When I attempt to turn it on, the TV makes a sputtering sound coming from the bottom right (if you are facing the tv) speaker area. It sounds as though it's...
SOUNDS LIKE YOUR LAMP IS OUT. AS FAR AS WHAT MITSUBISHI IS DOING THEIR NEWER DLP'S THEY REDUCED THE COST OF THE LAMPS TO $99. BUT ON THESE OLDER ONES THEY ARE DOING NOTHING.
Aug 17, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Turn on and red light comes on after two min. and it shuts off
on that model its possible for the lamp sockets from the ballast get pushed back inside the tv. Remove the bulb and verify that the sockets are firmly attached to the rear wall of the lamp compartment.
Jul 13, 2009 | Mitsubishi WD-52725 52". Rear Projection...
Problem with Toshiba DLP Projection TV Model #52HM84
It is possible the lamps may be defective or that they may be the wrong replacement for this model, as it may have a different wattage setup with the ballast. If you want to try to order the TB25 lamp from a different vendor, you can order the original Toshiba replacement lamp for this model (52HM84) from a major Toshiba parts distributor at the link below:
Toshiba 52HM84 Replacement Part TB25 Lamp / Bulb
Apr 10, 2009 | Toshiba TheaterWide 52HM84 52" Rear...
My DLP TV made a loud popping sound then went off
first. unplug the set for 5 minutes and see if it will reboot. if it does not the you have 2 problems, the chassis is also bad. next open the lamp door cover, it is behind the speaker grill, and behind the lamp door.
take out the lamp and see if it has broken on the inside if it has it needs to be replaced. mits will send you one i believe it is about 100.00 the number is 915P020010. if the lamp looks ok then the color wheel has probably fallen apart.if this is the case the light engine need to be repaired. check out www.tv-techs.com
Dec 31, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Loud buzzing noise
sounds like the color wheel needs to be replaced very easy repair on that model Samsung.
Jul 05, 2008 | Samsung HLR5067WX 50" Rear Projection HDTV
Loud Buzzing Sound
since you changed the lamp my next thought is that the color wheel has failed,,,most good road techs can replace it in the home..the cost would be between 220.00 and 350,00 depending on the company...
Nov 27, 2007 | Samsung HLP4663W 46" Rear Projection HDTV
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
191 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
