Question about Sony Grand WEGA KF50XBR800 50" Rear Projection HDTV-Ready Television
I turn tv on, works for two minutes, shuts off and the stand by light blinks 34 times and turns back on for two minutes then shuts down, stand by light blinks 34 times and keeps repeating.
  • Kim Yearick
    Kim Yearick Jul 17, 2010
    Your unit cannot be blinking 34 times as that is not one of Sonys codes. Perhaps you are counting the entire time the unit blinks. Sony codes blink at about a one second rate for the entire length of the code, stop, and then blink the code over again. They do this three times and stop. For 34 blinks that would mean perhaps 11 times 3 if you miss counted. Which is still more than the codes I have. Perhaps you should do a recount with what I have said in mind. Only count the blinks until there is a large gap in the sequence. Let me know so I can help you. Thanks for using FixYa. hardrocko
    New Friend:
Mine also blinks 34 times and then turns back on
Posted on Feb 27, 2011
6ya staff
SOURCE:
Code 34 replaced lamp with 2 new osram lamps may run for 5 min or 5 hrs shuts down solid red light code 34
I have a Mitsubishi model WD-60737 and to make a long story short 1st time problem lamp replaced fine for a month til my uncle hooked a DVD player to my TV next day turned on with solid green light then TV kept turning off after 2 to 3 minutes of beingetting turned on and a solid red light to show after. What does that mean? It's a brand new lamp and worked for a month so why shut down now? Could my uncle have did something to where it shook up the circuits or something?
Sep 25, 2014 | Mitsubishi WD-60737 60 in. HDTV
Sony KV-34HS420 shuts of and stand-by light blinks
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
Source
Sep 01, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
TV does not turn on. Stand By LED blinks 4 times and pauses and blinks 4 times again Tv will not turn on...when plugged in the red stand by light flashes 4 times...you can hear the tv turn on but a black...
On older Sony, sometimes a power surge causes the set to be in shut down mode. Try unplugging for 5 minutes and then plug in and try. This many times will fix.
May 31, 2009 | Sony KV-27S42 27" TV
Sony KV-34HS420 Random Shut downs
i would say this is a internal problem how long have you had it?
May 28, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony FD Trinitron WEGA Standby Light Blinks, TV Does Not Turn On
Sony FD Trinition Wega KV-32HS510 Try to turn tv on -it starts then shuts off -stand by lights keeps flashing. Memory stick light flashes then goes off.
Nov 29, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
KV32HV600
7 blinks meen
High voltage shut down , replace fly back transformer, shut down circuts and componets.
regards,
daniel.
Oct 22, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony trineton KV-34HS510
let me know how many times standby light flashes. this info will help me to assist you to resolve tv problem.
Sep 05, 2008 | Sony FD Trinitron WEGA KV-34HS510 34" TV
Sony wega
Would you like to tell me about stand-by light condition when TV goes to Off/ shut-down? How many times this light blinks?
Actually light-blink gives feeback about problem area. You can say it Error Code.
May 31, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony Grand WEGA KF50XBR800 50" Rear Projection HDTV-Ready Television Logo
151 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
