SOURCE: Gateway Flat Screen FPD1830
My Samsung 215TW started flickering like a strobe light when I would turn it on... then after a while, the speed of the flashing would change, and eventually, it would go out. After turning the unit on/off several times, I could get it to stay on, but after a while, it would start to get odd video noise (strange colors appearing on the screen), and then it finally quit.
Once the monitor went dead, I noticed that I could still see the image on the screen, albeit very dark, so I took my desk lamp, and placed it next to the screen, and I could see that the monitor was still active, meaning that there was an actual image on the screen, it was just that the fluorescent lamp that lights the screen was not staying lit.
I got tired of waiting for Samsung's customer service (thats a story all within itself), so I took the monitor apart in search for the problem (I am an electrical engineer and electronics specialist). I saw that there were two circuit boards, one being the power supply board, and the other being the video signal board. Knowing that there was still a video signal present, I focused on the power supply board, as it contains the transformers to ramp the voltage up to the necessary voltage to light the lamps.
I instantly noticed that several of the radial electrolytic capacitors on the board were bulging and looked like they had swollen and then blown. There are 5 caps on my monitor that needed to be replaced: (1x) 47uF/50V, (2x) 820uF/25V, (2x) 330uF/25V.
The 47uF and 820uF caps are on the power supply side of the lamp power circuit, and the 330uF caps feed the control signal into the IC chips that control the ballast of the lamps themselves, one for the upper lamp, the other for the lower lamp.
Once I replaced these units, my monitor started functioning correctly, and I dont have to give Samsung my absolute most favorite monitor ever for a refurb unit that most likely will have 15 dead pixels on it (mine has ZERO).
SOURCE: Monitor flickers unless brightness is at 100%
Go to your Windows display settings and hit the Advance button and try changing the refresh rate on the monitor.
See if that helps.
SOURCE: monitor turns pink quite frequently
i think problem is the vga cable of monitor try to remove the cable of your monitor attache to pc or try to reconnect the vga cable
SOURCE: Samsung 226bw visible flickers just after it is turned on
You may have a faulty inverter or loose power inverter connection. OR
You may have a defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
