The first time the Worx GT worked great since then I took it off the charger and it won't go more than five min. without going dead. I'm back using my gas trimmer what's up ith th battery on the Worx Gt
Mine does the same thing. I don't know what is wrong the battery or charger b/c it will charge a but then the light goes from red to green and keeps going back
I got mine last year and it's doing the samething
THE FIRST TIME I CHARGED THE BATTERY IT WORKED FINE. THE SECOND TIME I CHARGED IT THE LIGHT WAS GREEN THEN CHANGED TO RED AND BACK TO GREEN IT HELD THE CHARGE BUT THE NEXT TIME I TRIED TO CHAGRE IT THE LIGHT WAS GREEN AND STAYED GREEN AND THE BATTERY HAS NO CHARGE AT ALL.
Did fine for one year and now it will not hold a charge.
It happened to me. I discovered it's the charger, not the battery.
I had the same issue with my Worx battery.
Check to see if you are eligible to receive a free battery replacement:
http://www.worxbattery.com/
We had the same problem with our battery. It worked fine for 18 months. Then, this summer, it just wouldn't work at all. We left the battery on the charger until the light went green (we tried this several times) but still the battery wouldn't work. I hooked it up to a Volt meter to verify that the battery was the problem and it was only pulling 1.7 volts (not the 18V the battery for the WG151 model is supposed to have).
Mine as well. I can't see how to get the replacement???
