I turned it off and then turned it on again a few second later and it stopped working.
The brush was clogged with string and hair, so I cleaned it out. Still wouldn't work (10 min. later)
checked power outlets
I had a similar thing happen and just got off the phone with dyson. there is a resettable switch on the handle. they told me to start the vacuum in the upright position, put it in the non upright position, then push and hold in the beater bar switch which is located next to the on/off button for 10 seconds and the beater bar should start to function once again
Dyson has a built in mechanism to stop it from switching on if it over heats and it takes longer than 10 minutes to reset leave it cool completely then try again if this doesn't work it will need to be repaired either contact dyson or the shop where you bought and arrange to have it fixed
