Maytag Neptune MAH5500B Front Load Washer Logo
Posted on Jul 15, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Maytag Neptune front load washer continues to fill with water.
My Maytag Neptune front load washer continues to fill with fresh water after the wash, rinse and spin cycle is complete, causing the door to open and flood the room. Why?
  • Anonymous Sep 20, 2012
    I have this same problem with my Maytag Neptune. The repairman did not fix it. Help!!
  • Official Brand Answer 408 Answers
  • Posted on Jul 17, 2010
Whirlpool
Level 0:
Answers
408
Questions
0
Helped
157837
Points
784
Maytag neptune tl top load washer - the cold water continue to fill and over flood the tub.
Pull the washer 120VAC power cord. Does water continue to flow into the machine?
If yea you have a Stuck Open water valve. If know then you may have a stuck pressure switch.
Are you going to try to DIY the repair? Further troubleshooting will be required.
The cold cycle on my Maytag Neptune front load washer is not working. It works fine with hot water.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Maytag neptune washer wont fill water
It is very possible for it to be a valve failur as these machines have a temperature control incommon, It recieves voltatge through the temp control.
2answers
On my Maytag Neptune MAH-3, the water is running non-stop
check plastic hose out side of tub to pressure switch
if ok replace pressure switch
1helpful
My Maytag Neptune leaks water from the bottom (immediately) as it fills with water
usually this is from the front door seal going bad remove the front panel and door to replace it
3helpful
MAYTAG NEPTUNE MAH9700AWW continues to fill on rinse, code "oe",
if the water continues to fill even with power off, and you have to manually shut in off at the wall valve, the 3-way inlet valve is stuck open. you have to replace it. $90
2helpful
Water will not shut off, continues to fill
does the water run when you unplug the machine? if so then you have a bad fill valve,
2helpful
Water fill
Try unplugging the unit. If it stops filling you have a control board problem. If it continues to fill, you have a bad fill valve that is not closing properly, usually because of dirt or scale buildup thats gotten past the inlet screen on the valve. Good Luck!
Top Maytag Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
