Microwave Ovens Logo
Posted on Apr 20, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My LG Combi Microwave oven MC 806BL flashed up error code F2 while pre-heating the convection oven. Now it is not cooking properly on any setting. Is it completly broken?
  • 3 more comments
  • dawnrazor Apr 20, 2008
    To clarify, the plate is turning and the light is on but there is no heat on microwave, convection or any of the settings. Basically it is not cooking/heating up at all.
  • dawnrazor Apr 21, 2008
    There is nothing wrong with the door. It is simply not cooking.
  • William Miller
    William Miller May 11, 2010
    Can you clarify what you mean by "not cooking properly on any setting"?
    Thanks.
  • Anonymous Mar 13, 2014
    My microwave convection oven just stopped working and the error code 0--o came up.
  • Anonymous Mar 20, 2014
    Error code f2 is displayed on screen once the cooking has completed
William Miller
Level 3:
  • Microwave Ovens Master 9,179 Answers
  • Posted on Apr 20, 2008
William Miller
Level 3:
Answers
9179
Questions
Helped
4479601
Points
21747
This is usually caused by either a bad door switch (usually the top one), a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
[email protected]
http://www.microwavedisplay.com
  • William Miller
    William Miller Apr 21, 2008
    Sorry, but how was my solution inappropriate??
    Looking at recent model LG microwave schematics, everything points to a failure of the top door switch or its mount...
    I would again refer you to my answer above.
  • William Miller
    As shown in the sample drawing below, there are hidden switches that get activated by the hook-like projections on your microwave's door whenever the door is closed.
    That's how the microwave knows whether its door is open or closed.
    One of those hidden door switches (probably the top one) is not getting activated when the door is closed.
    That's why it won't heat.
    It's a little bit like the door switch on your clothes dryer - if you open the door, it stops running.
    Or the door switch on your fridge that turns the inside light on when your open the door and turns it off when you close the door.
    Sorry if I didn't make that clear.
1helpful
What does F2 mean?
The error code F2 on your GE microwave indicates "Shorted thermal sensor", this condition will occur if a shorted thermal sensor is detected continuously over 5 seconds on convection, combination or roast cooking.
. It takes a minimum of 5 minutes of convection run time before this code will be
displayed. More information on this error code, as well as other error codes, can be found at
http://www.applianceaid.com/micro_faultcodes.html#gemicro
Best of Luck with your microwave.
My Sharp microwave convection oven (R-967M / R96STM) cuts out during convection pre-heating and cooking, It appears it stops heating after 1 min. If the START button is pressed again the oven starts...
Also the fact it is a convection oven could mean the oven temperature sensor is not picking up the oven temp. it is not telling the machine it is there by the board seeing its resistance, the unit will shut off as a safety feature. The oven sees temperature by reading the value of a temperature dependent resistor. As the temperature changes so does the value of the component ( oven temp sensor) that way the unit determines the temperature inside the unit. Sometimes those sensors will break since they are in the area with the heat and moisture, they get old and break.
9helpful
Glass turntable in tricity tmc209 says "microwave only" What do I use for convection or combi cooking? Does turntable still need to rotate for convection cooking?
definately dont use the standard glass plate for convectional 'oven' cooking, as it will shatter. i have had TWO plates shatter so far before realising they should only be used for microwave cooking.
My LG MICROWAVE OVEN IS MODEL MC-7836M CONVECTION MICRO GRILL IT IS RUNNING BUT NOT HEATING and GRILL ALSO NOT WORKING
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
Cooking temp to bake cake inn convection mode samsung model
Hi I guess you are cooking usng the combination setting? if so The cake will be hard due to increased microwave energy, I would suggest reducing the microwave energy on the Samsung unit when using the combination setting.
Hope this helps
I have a siemens combi micro oven, which is the best way to cook a christmas cake and at what temp
with the convection part at 325 deg, for 1 hour or less depending on the cake size..have fun cooking..
Microwave has stopped working and now I receive a flashing No10 in a square and a flashing No 1 in a square.The rest of the oven works, the convection side, What now....help!?
My wife cannot wait forever for me to solve the problem with our Microwave....so I nhad to bite the bullet and take it in to LG for repairs.
Thanks for the good site
Top Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a Microwave Oven Expert? Answer questions, earn points and help others
