I'm trying to make some black and white prints from some digital files. they look black and white on my mac screen, but when i print using, grayscale, or desaturate the prints look reddish. if i go to image/color balance and reduce high/medium/shadow even very small amounts, my prints look cyan/green. i'd really like to know how to make prints that are equal in beauty to my old silver gelatins. i've also tried many kinds of paper. my new favorite is harman professional inkjet matt. is the canon i9900 pushing red some way? why won't it just use black ink for desaturated files? arrrrgggghhhh. steve
I sympathise! I also have had this problem, and not really found an answer. If I print a B&W photo using 'grey shades' I get a nice 'olde tyme' effect in dark brown - but not black.
Sorry, steve, that you are experiencing this problem.
According to canon.com's website regarding the i9900 InkJet Photo Printer:
Why color ink may be used when printing in black and white
Even when printing in black and white, color ink is used for the following reasons:
I might suggest taking out the color ink cartridges leaving only black there, but some printers don't take kindly to this. So, you may have to further experiment with magenta, cyan, and yellow to make it at least seem b&w to your best eye's judgment.
To prevent the print head nozzles from clogging, the print head is automatically cleaned periodically. At that time, a small amount of each color ink is consumed.
Therefore, although printing in black and white is performed, color ink is also consumed.
When printing in grayscale or on photo paper or when duplex printing, although printing appears in black and white, the color black may be created using the three (cyan, magenta, and yellow) color inks. Printers without a pigment black tank / cartridge will print black / grayscale will create a composite black using color ink even on plain paper.
Therefore, although printing in black and white is performed, color ink may be consumed.
Good luck on this.
For Windows OS:
1. Go to Control Panel.
2. Open Printers and
Faxes.
3. Right-click on Lexmark
3600-4600 Series print object and click on Properties.
4. In the Lexmark 3600-4600 Series Properties window, go to Advanced tab. Click on Printing Defaults.
5. In the Lexmark 3600-4600 Series Printing Preferences window, under Ink Use, select Print
using black ink only. Click OK.
6. Click OK button in the
Lexmark 3600-4600 Series Properties window to save the changes.
Your printer will print in
black and white draft mode the next time you send a print job to the printer.
For Mac OS:
1. With the file (you wish
to print) open, go to Print. A window will pop up.
2. Select the Lexmark
printer.
3. Expand the arrow
pointing down beside printer name if you're not able to see other options for
printing. Look for Quality and Media.
4. Under Paper tab, select Print in Black
and White.
5. Save this as your
default print setting. Click Presets option and choose Save as. You can
personalize the name for this default print setting (e.g. Black and White Draft
or My Setting).
Select this Preset name
every time you print your files/documents.
The Grayscale print option optimizes the look of color slides for printing on a black and white printer by adding shading. The Pure Black and White option prints your slides in monochrome.
