The display board failed (part # 8205663) and I received the replacement part from KitchenAid. I need to access the controller interface board to swap out the part but I don't see any screws securing the trim over the controls.
Do I need to remove the entire unit from it's cutout to access the cover screws from the backside or does the control panel trim piece somehow snap on/off?
I have the repair part list, installation instructions, and tech sheet PDFs but none are clear on the method.
Thanks
SOURCE: Kitchenaid KBMC147HSS0 Bulb replacement
If it's the one that lights the cooktop, it's normally beneath the bottom cover.
In some cases, it's located in a compartment behind the grille that goes across the top of the unit.
I have a diagram at my site which helps you find & replace many GE cooktop and cavity light bulbs. It may help. It's at http://207.234.249.73/mwd/ge_lamp_replacement.jpg
Please let me know if that helps or not.
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: How do i replace the door handle
with most microwave ovens, for safety reasons... they are permanently sealed to prevent microwave leakage burns... i hope this helped you out..
