Posted on Apr 20, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
GENX Softwear needed
I purchased a GENX Scanner and was using it for the past 3 years; however when my computer was getting hang ups I had the CPU sent to the mechanics who had all drivers un installed. and window XP reinstalled and sent it back to me.
Now when I wish to install the GENX scanner I find my son has misplaced my scanner softwear CD
So could you help me re-install my GENX scanner. Thank you
  • Anonymous Nov 23, 2008
    genx scanner 600 dpi install now
  • Anonymous Mar 06, 2009
    I purchased a GENX Scanner model RCFA4601EUand was using it for the past 3 years. I have fomatted the PC and reinstted window XP.
    Now when I have misplaced my scanner softwear CD
    Please help me re-install my GENX scanner. Thank you
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 23, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1695
Points
9
بدي تعريف سكانر من نوع genx600ومش عارف أجيبة
Anonymous
Level 1:
  • Posted on May 05, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1695
Points
ده سيدهايه التعريف لأسكانر من نوع GENX و اسم الموديل 600DPI وقم تعريف الموديل هو RCFA4601EU
http://www.xtrememea.com/ftp/sc_smar..._driver_v1.zip
وده هديه لكل الناس الى دايخين على اتعريف ده ومش لاقينه وحتى مش موجود على موقع الشركه
ولو الرابط وقع ممكن تبعتولى على الميل [email protected]
وانا ارفعهولكم تانى ومتأسف على كتابه العنوان بالأنجليزى بس ده عشان يظهر على مواقع البحث مثل جوجل
Pierre Wepener
Level 2:
Scholar:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 137 Answers
  • Posted on Apr 21, 2008
Pierre Wepener
Expert
Level 2:
Scholar:
Cheetah:
Answers
137
Questions
0
Helped
23859
Points
195
You must install the driver for the Scanner.
You can download the driver from the link below, make sure you select the model as it is not mentioned in your request and therefor provided you the link to all drivers for GenX. Make sure the scanner is powered off before installing the driver and power on only on request by the setup application (follow the on-screen instruction) http://list.driverguide.com/list/company2397/
I trust this will help.
Regards
Hands of Time
1helpful
2answers
Computer hangs after startup
- Stop Overclocking your CPU.
- Make sure your Heat Sink is placed properly above the processor.
- Clean the Processor fan, Heat Sink and other peripherals.
- Use High Speed fans.
- Use CPU Heat Sink Paste in the processor.
- Fix OS registry with reliable program like I always use Reginout.
- Shut down your computer at least two hour a day.
Hope these tips will help.
Exceed hangs with high CPU usage
Hello Djelliott19, It's executive file with some instruction. "exceed.exe" is a method of delivery for virus/malware infection. so please beware. You should perform these basic steps.
1. Clean history
2. fix registry
3. uninstalled every unknown programs
if you still stuck, recommend to call me at +1 (844) 355-5111 (toll-free) number.
Thanks
John
Hello, i need Genx scanner driver
Please check this link. This is the only driver that I've found:
http://www.genxmea.com/default.asp?action=category&ID=26
Hope it helps. Have a great day!
18helpful
3answers
GENX Scanner
i want genx 600dpi softwear plz help me
2answers
Sometime,alternatively my computer gets hang at the beginning showing intel
1.If VGA onboard on your Motherboard Pl try Extranal VGA cord.
2.Apply Heatsync paste Properly at CPU.
3.Check any bulch capacitors on MB.
4.check CPU Fan and change it.
Was this solution is use ful Pl appreciates my ratings.
Replace heatsink fan on CPU.
The thermal paste should be cleaned off. Clean the CPU and heatsink fan with a dry cloth, which should remove the paste quite well. It is simply a viscous liquid and should not require scraping.
You should replace the thermal paste when installing the new fan. You can purchase it at your local computer supply store. Simply place a small dab of it on top of the CPU and then install the fan.
If you try to re-use the existing thermal paste, you will not get reliable heat transfer from the CPU to the fins.
7helpful
3answers
k24674
ADMIN Andrew
ADMIN Andrew
