See above
It is a drain error code signifying that the pump is not able to completely drain the machine after 10 minutes. It indicates an issue with the drain system. Check to make sure that the drain hose is not clogged and the pump filter is clear from any obstruction. Consider replacing the pump assembly if no issue is found with the drain hose and the pump filter.
You don't have to accept or reject
and rate this post
to add information
or post comments and follow-up questions.
Accepting a solution does not stop you from posting
comments or
follow-up questions. You can continue communicating with an expert as
long as you need assistance regarding the issue stated herein.
