AT&T E580-2 Cordless Expansion Handset Logo
Posted on Jul 13, 2010
How do you turn off the ringer on an ATT phone.
How do you turn the ringer on/off on aatt 993 2 line phone
If you mean the AT&T 993 two-line speakerphone, you can adjust the ringer volume for each line when the phone is not in use. To increase the ringer volume on the primary line (if set), press the Volume Up arrow. To decrease the ringer volume, press the down arrow. There are 8 different volume levels available for the ringer. The Volume Up/Down buttons are below the * and 0 keys.
To adjust the ringer volume on the secondary line, press that line button (between the Conference and Hold buttons) and then press the Volume Up or Down buttons as needed. (If you haven't programmed a primary line, press a Line button and adjust that line's ring volume before pressing the other Line button. Then adjust the volume for that Line.)
I hope this helps. These directions are shown on page 32 of the manual. AT&T currently has the manual here : https://att.vtp-media.com/ecp/documents/product_Product/227/UserManual/5596/993_manual_i14.pdf . To find this manual or other AT&T phone manuals, start here: https://telephones.att.com/product-support/manuals .
How do I reenable the ringer on my ATT 993 phone. The phone does not ring
Make sure to look on the phone itself, and see if there might be a button on the unit, or base station, that turns the ringer on/off.
How do I adjust ringer volume on wired ATT two Line phone model 993
VOLUME buttons;
During a call, press to adjust the listening volume.
While the telephone is not in use, press to adjust ringer volume.
How do i turn my ringer off on my at&t model 1855 phone?
Press the VOLUME up or down button while the phone is idle to adjust the volume. There are seven volume levels and volume off. Each button press will increment the volume level up or down by one level. The screen will show the volume level while you are adjusting it.
How do I turn off the ringer on my phone
Since you declined to specify the model of your Uniden DECT 6.0 phone I can only suggest that you select it from the list beginning here to download a copy of the manual.
Problems with ringer
the best advice would to take it back to the mobile store and have them check it or replaced it for you.
Ringer
what you should do is just change the phone, take it ack and have them give you other model instead of the V3m.
Top AT&T Lands Phones Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
